Zetec / zvh crank positon sensor info
Old Sep 9, 2007 | 09:35 AM
R6Franky's Avatar
R6Franky
Default Zetec / zvh crank positon sensor info
Hi,
I've got a 2.0 zetec block (auto) ready to drop in but I've got issues with the CPS. The housing I've got sets the sensor at a slight angle and the OFAB fiesta sensor I'm using is also too long and fouls on the back of the efi flywheel.
What does everyone else use (housing/sensor combo?), Haven't read of anyone having problems with this before.
Thanks
Dan
Old Sep 9, 2007 | 11:45 AM
Šhatter Box's Avatar
Šhatter Box
you need to change the cps holder in the block for an non auto one
Old Sep 9, 2007 | 02:08 PM
R6Franky's Avatar
R6Franky
I know,
The one I've got isn't the auto one as that was set at the wrong pcd for the flywheel pickup. This one is correct but angles the cps slightly. I'll try and get another one from the scappy. Mine must've been bodged previously. Cheers
Dan
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
mike elsome
Sep 14, 2015 04:08 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
BRAM
Sep 8, 2015 07:11 AM
