lambada sensor 2wd sapphire
Old Sep 7, 2007 | 03:10 PM
capri280's Avatar
capri280
Default lambada sensor 2wd sapphire
can anyone help i have bosch lambada sensor 2wd sapphire
can anyone the wether the white or black wire on the lambada probe goes to pin 2 on the ecu
had to seperate mine to cut hole in turbo heat shield and have mixed two wires up
help asap
regards
eugene
Old Sep 7, 2007 | 04:27 PM
Black is ALWAYS signal,
White is earth on two wire, but on 3 or 4 wire one white is earth one is live for heater.
This is for ZIRCONIA sensors.
On TITANIA sensors black is signal, white is negative(earth) on three wire or on four wire, white is REFFERENCE, ie live from ecu, not TO IT.
Kam B
Sep 24, 2015 10:40 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
3doorcozmess
Sep 15, 2015 06:06 PM
mike elsome
Sep 14, 2015 04:08 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
