fuel consumption
Old Sep 5, 2007 | 08:54 PM
bullseye's Avatar
bullseye
Default fuel consumption
hi was just wondering what u peeps where getting miles wise from a full tank of jucie. ive got an s2 board out 0.50mm kent fast road cam low comp pistons k and n full mangnex exhaust collins -31 acuator set at 12 psi. iam only getting about 160 miles to a full tank i use the car every day and dont realy boot it is this about wright?????
Old Sep 5, 2007 | 09:39 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Not very fair to compare to mine, but I get 200-220 miles to a tankful. Mixed driving, but with 30psi available, GT30 and 350bhp.
Old Sep 5, 2007 | 10:07 PM
Chris69's Avatar
Chris69
thats very bad mate you should be seeing alot more than that, summit ain't right
i'm seeing 200/250 from a tank and thats not being light footed!
Old Sep 7, 2007 | 06:44 PM
bullseye's Avatar
bullseye
any ideas what cud be wrong, no black smoke or fuel leaks and the car drives sound
Old Sep 8, 2007 | 08:58 AM
JesseT's Avatar
JesseT
I regularly get around 340 miles to a tank in urban driving running ~22psi and around 250hp of power in a standardish 1.6cvh.
spark map is very aggressive off boost and target boost is mapped to follow the accelerator pedal to save fuel. Fuel mixture is controlled 100% closed loop all the time.
With 160 something is definately wrong. Have you checked your fuelling, cam and ignition?
Old Sep 8, 2007 | 09:37 AM
bullseye's Avatar
bullseye
timing is spot on oly passed mot last mounth and emmitions where spot on
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
