arp mainstuds is this right?
Old Sep 2, 2007 | 06:18 PM
Mark_1's Avatar
Mark_1
Default arp mainstuds is this right?
Ive finger tightened the studs and this was as far as they went
i believe this is not right?
the umbrako hole is facing upwards, so i havent put it the wrong way..
Old Sep 2, 2007 | 07:09 PM
It is NOT right, did you clean/tap the holes out, and degunge the base of the hole of old hardened oil ?
Old Sep 3, 2007 | 07:53 PM
Mark_1's Avatar
Mark_1
im pretty shure that it isnt hardened oil at the bottom of the hole as it did look clean, but i didnt scrape the bottom with a screwdriver or so.
if i turn the stud around it is a perfekt fit, does anyone know if its the longest or shortest threaded part of the stud which is supposed to go into the block?
Old Sep 4, 2007 | 05:29 AM
If you look very carefully one end will have a tiny shoulder/rest that goes in the block.
You should scrape out any crap that is down the holes first.
little bram
Sep 27, 2015 07:45 AM
IainRS1700T
Sep 25, 2015 06:44 AM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
