Greddy PRofec B-Spec II Boost Controller
Old Aug 31, 2007 | 09:35 PM
Mark_w's Avatar
Mark_w
Default Greddy PRofec B-Spec II Boost Controller
Does anyonyone run a Greddy PRofec B-Spec II 2 Boost Controller on their cosworth???I have just bought one for mine and wondered if anyone had any tips on setting it up as its a bit confusing.
regards mark
Old Sep 1, 2007 | 07:46 AM
Hrsturbo's Avatar
Hrsturbo
I got one on my rs turbo, I started off with everything at 0 then adjust slowly each time untill you get to the boost setting you want then you can play with other features to hold the boost stable and not drop off etc.
make sure you set max boost first! I dont let mine peak but you might want to so you need it higher than what you will be running
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
