new headgasket/still overheating
Old Aug 31, 2007 | 10:56 AM
sy.rst's Avatar
sy.rst
Default new headgasket/still overheating
i fitted another engine in my s2 rs turbo asoon as i drove it up the road it over heated i run a compresion test and found that cylinders 1 and 4 were low,so i replaced the gasket and also the head coz i had a spare head at home that was off a old engine of mine coz i know it was good.but it is still overheating i have removed the thermostat.the fan runs constant,the rad seams to be flowing ok.am running out of idears.
Old Aug 31, 2007 | 04:13 PM
mrjenrst's Avatar
mrjenrst
Have you checked the block to see if its warped?
After replacing the head did you do another comp test?
Why did you replace the original engine?
How do you know the new head is ok?
Old Sep 1, 2007 | 05:10 PM
mumbo jumbo's Avatar
mumbo jumbo
has the water pump given up or even is your rad blocked up
Old Sep 8, 2007 | 10:58 AM
sy.rst's Avatar
sy.rst
Default over heat
i did a compression test wiv the new gasket and all cylinders were good,also took the top water hose off and cranked the engine and it was pumping water out so pump is fine.
Old Sep 21, 2007 | 03:12 PM
sy.rst's Avatar
sy.rst
Default bttt
bttt
Old Sep 21, 2007 | 03:23 PM
jawanne's Avatar
jawanne
hi have you got the water pipes the right way .and does it over heat when stud still..or does it over heat when driving..as it could stil be your water pump
Old Sep 22, 2007 | 04:53 PM
sy.rst's Avatar
sy.rst
it doesnt over heat when standing but boils rite up asoon as i drive up the road.
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Ade
Feb 8, 2007 05:11 PM
kurdt5
Jul 17, 2006 03:01 PM
fiestaturbo1984
Feb 19, 2006 03:51 PM
woodz77
13
Nov 6, 2005 03:02 PM
