Ignition module wires
Old Aug 30, 2007 | 03:35 PM
warrenja1's Avatar
warrenja1
Default Ignition module wires
Hi,
Does anyone know the pinouts on a sierra cosworth ignition module.
Im actually stuck with the 2 wires that go to the ecu(pin 24+25). I know 1 must be a trigger wire but i cant figure out what the second one is for?
Anyone have any ideas? Im putting a motec ecu into my 4x4 saph and hopefully this is the last complication before its running again
Thanks
John
Old Aug 30, 2007 | 04:29 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
1 output to coil
2 gnd (0v)
3 trigger gnd from ecu
4 pos (12v)
5 not connected
6 trigger pos from ecu
7 not connected
Old Aug 30, 2007 | 10:23 PM
jon@work's Avatar
jon@work
http://www.motec.com.au/drawings/m11.pdf
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
