Oil Cooler??
Old Aug 30, 2007 | 02:43 PM
Staffi's Avatar
Staffi
Default Oil Cooler??
As above, yes or no to fit one?? i don't really do many track days, car is mainly weekend toy, might do a couple next year, would just like peoples views really..
Old Aug 30, 2007 | 09:19 PM
Tev's Avatar
Tev
no expert fella but i would say no, u can end up over coolin the oil if not carefull,
Old Aug 30, 2007 | 10:20 PM
jon@work's Avatar
jon@work
ask Karl
Old Aug 31, 2007 | 06:13 AM
Overcooled is way more preferable to overheated.
Recent tests done by a famous oil co showed that the engine oil tends to be 30-40 C HOTTER than the water temp, as it does at least as much cooling as the water.
Most oils will start to break down at 135C or thereabouts, so most std cars are on the limit, but that is mass production for you!!
Fit one but with a stat then you have the best of both worlds, the std modine was fitted as it warms the oil quicker, not just for cooling purposes.
Brickhouse
14
Oct 3, 2015 07:28 PM
