Rs turbo wont start, HELP!!!!
Old Aug 27, 2007 | 04:39 PM
Russ Payne's Avatar
Russ Payne
Default Rs turbo wont start, HELP!!!!
Hey every1 got a series2 rs turbo, but it wont start, got a spark and fuel going to the metering unit but its only comin out on number 1, also when u turn it over it just bangs and thars it, any ideas
Old Aug 27, 2007 | 05:19 PM
project rs's Avatar
project rs
what were you doing to it when the problem started or what had you just fixed or swapped over
Old Aug 27, 2007 | 05:36 PM
Russ Payne's Avatar
Russ Payne
well i actually have just put the engine in my mk 4 escort van
Old Aug 27, 2007 | 08:01 PM
project rs's Avatar
project rs
firstly check to see if the metering head flap is bouncing when your cranking it over as thats a good sign you've got no air leaks. next check your battery is fit for the job as sometimes weak battery gives slow engine turn and weak spark. what tank and pump you using
Old Aug 28, 2007 | 06:25 AM
Russ Payne's Avatar
Russ Payne
using a diesel tank with the swirl pot from a series 2 tank welded in, and a series2 pump
Old Aug 28, 2007 | 08:21 PM
project rs's Avatar
project rs
did you look to see if the metering flap is moving
Old Aug 30, 2007 | 04:01 AM
vivien62's Avatar
vivien62
hi,dont want to sound like a dummy,but check the simplest things first,sounds like in your hurry to get the engine running you have put your ignition HT leads in the wrong order
Bailes1992
Aug 16, 2015 07:14 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
rs_turbo_ant
Aug 8, 2015 11:11 AM
Bloody-Fox
Aug 3, 2015 07:48 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
