s2 brake problem !!
Old Aug 26, 2007 | 09:26 PM
B1G_RST's Avatar
B1G_RST
Default s2 brake problem !!
ok so car failed its mot for brakes,bryakes were great then on the day of its mot th pedal goes straight down! so get her back from th mot station and obvs failed,so i changed back shoes (as they wer worn) and a rear brake adjuster was replaced.so once all that was done i bled the brakes but stil goes down,so i then bled the master cyclinder but now is worst.
any1 no what this is now,im thinkin master cylinder seals are fukced?
cheers sean
Old Aug 26, 2007 | 11:31 PM
Grandad racer's Avatar
Grandad racer
master cylinder whould be what id go for
Old Aug 27, 2007 | 08:59 AM
project rs's Avatar
project rs
if you've got abs fitted then they need bleeding seperatly to rest of system and make sure you've got the rear adjusters open i.e wheels on and weight of car on them or to rule rear out lock them off and that will give you just the front to play with and if ok when locked off you've got air in system still in back
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
