help car has no power
Old Aug 26, 2007 | 08:53 PM
gee1599's Avatar
gee1599
Default help car has no power
my car has no power at all no missfire new every thing
but when you drive it its just so flat its boosting fine but no power any advise or tips
Old Aug 26, 2007 | 08:58 PM
Badman38's Avatar
Badman38
Default Re: help car has no power
need more info cam, mangement etc
sean
Old Aug 26, 2007 | 09:16 PM
gee1599's Avatar
gee1599
car is std apart from air filter exhaust chip and -31 act and a grs front mount
Old Aug 27, 2007 | 08:48 AM
project rs's Avatar
project rs
did this start after you did something or just appear one day
Old Aug 27, 2007 | 08:56 AM
gee1599's Avatar
gee1599
it started at high rpm now its all the time i have fitted new plugs,leads,cam kit,timing belt (timing all correct) new boost hoses new dissy new air temp sensor new head gasket and the list gose on
it is just so flat my 1.2 corsa is now faster
Old Aug 27, 2007 | 09:02 AM
project rs's Avatar
project rs
have you got a boost guage fitted just wondering if your leaking boost via actuator
Old Aug 27, 2007 | 04:18 PM
James Raby's Avatar
James Raby
is the turbo spinning? take the hose off and try to turn the wheel, i had this on mine when it was running, got stuck then freed itself and back to power!!
Old Aug 27, 2007 | 05:32 PM
gee1599's Avatar
gee1599
car is boosting fine and holding 16psi through the hole rev range with no faults its like the ingnition timing is out but its not
Old Aug 27, 2007 | 06:01 PM
James Raby's Avatar
James Raby
so you're taking the boost gauge for truth? You don't actually KNOW it's boosting?!
Old Aug 28, 2007 | 10:55 AM
homer j's Avatar
homer j
mate get it setup pronto! could easily be running lean which in the long term (or even the near future) will mean lots of scrap metal were your pistons used to be.
regards
tom
Old Aug 28, 2007 | 11:10 AM
smitsturbo's Avatar
smitsturbo
also check all your hoses as a burst one or slack ones would also cause problems
Old Aug 29, 2007 | 09:23 PM
dave_y's Avatar
dave_y
i had this problem, well identical symptoms and i swapped the fuel injectors and its been fine since.
Old Aug 29, 2007 | 09:30 PM
gee1599's Avatar
gee1599
it has new injectors new samcos i would get it set up but i cant get it there its has boost with no faults its like the timing is so far retarded but its set to 12* btdc i need advise to get it running semi-o.k so i can get it to the rolling road as the nearist one is 80 or so miles away
Old Aug 30, 2007 | 03:48 AM
vivien62's Avatar
vivien62
hi,how about the fuel pump,i know that if your fuel pump is on the way out it will not work properly on acceleration,yeah it will still cruise but when you put your foot down you will have no power.
Old Aug 30, 2007 | 07:22 PM
gee1599's Avatar
gee1599
new fuel pump and filter and injectors and fuel lines every thing is new
Old Aug 30, 2007 | 07:35 PM
project rs's Avatar
project rs
slight chance is cam's worn out and valves not opening properly and thats why its got worse as cam lobes have got worse
Old Aug 30, 2007 | 08:32 PM
Drag_steer's Avatar
Drag_steer
see spark plug colour I have problem with my, to lean, mixure was 15:1 at boost, look if cambelt snapped maybe
Old Aug 30, 2007 | 09:40 PM
gee1599's Avatar
gee1599
new cam kit , plug colour is spot on co set up to every thing is new on it
every thing from block up is brand new inc cam belt and cam kit i just dont no going to set fire to it soon
Old Aug 30, 2007 | 10:19 PM
Mr.h.'s Avatar
Mr.h.
Had the same on my s2 a couple yrs ago, turned out the dizzy was shagged, timing set to 12 ect but felt retarded! New dizzy then all was well again
Old Aug 31, 2007 | 03:06 PM
rsj's Avatar
rsj
i had this prob a few weeks bk my car was boosting fine holding 16 17 psi same as u it was like driving an xr3i but worse, alterd the timing slighty and away she went like it shoud be doing but now with the power increase my pissing clutch is slipping
id try it mate it worked 4 me
Old Aug 31, 2007 | 03:12 PM
LEE-RS's Avatar
LEE-RS
Custom
could be a faulty knock sensor which is retarding your timing (green plug on right side of manifold)
or it could just be that your ignition timings to retarded (you see its boosting fine but its low on power and not pulling very well )
Old Aug 31, 2007 | 04:46 PM
Fiecos Dan's Avatar
Fiecos Dan
A few options, that might help.
- Comp, and leak down test?
- Pressure test boost system for leaks, and test your gauge.
- Cam timing (not ignition) could be 1 tooth out, = full boost but lack of power.
- Ex housing cracked on turbo? or wastegate sticking/leaking?
- Fueling pressure and flow check?
- could be ECU or Metering unit or sensor?
- under load timing and fueling check?
- spark plug gap?
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
track.focus'd
Aug 12, 2015 05:53 PM
marvin
Fiesta RS1800/RS Turbo
Aug 10, 2015 11:14 PM
Old ford
Jul 31, 2015 06:50 AM
