temperature gauge goes straight to hot
Old Aug 26, 2007 | 08:47 PM
turboben's Avatar
turboben
Default temperature gauge goes straight to hot
i have recently done a efi conversion on my s1 which i had loads of problems with and cut a lot of wires trouble is now once all wired up with in about 5 minutes of the engine running the gauge goes above the red i have changed the temp sender and cleaned the connectors what could it be anyone got any ideas
Old Aug 26, 2007 | 08:59 PM
Badman38's Avatar
Badman38
Default Re: temperature gauge goes straight to hot
Originally Posted by turboben
i have recently done a efi conversion on my s1 which i had loads of problems with and cut a lot of wires trouble is now once all wired up with in about 30 seconds of the engine running the gauge goes above the red i have changed the temp sender and cleaned the connectors what could it be anyone got any ideas
the feed for the sender is earthing out somewhere.
sean
Old Aug 26, 2007 | 10:54 PM
turboben's Avatar
turboben
but it does just go straight up when the engine is running it goes up slow takes about 5 minutes
Old Aug 26, 2007 | 11:07 PM
Micky's Avatar
Micky
aS ABOVE,ITS earthing somewhere.Regards,MICKY
Old Aug 26, 2007 | 11:20 PM
turboben's Avatar
turboben
is there a comon place where these earth out and how would i test it
Old Aug 29, 2007 | 10:31 PM
gup's Avatar
gup
if you follow the temp wire back you may of cut it by accident and its touching the body fella
Old Aug 30, 2007 | 06:18 AM
turboben's Avatar
turboben
i cant see it being an earth problem tho as if the keys are in the ignition and its on it will just go above the red but it will take about a minute to get there then when you start the car it will go into the red but it will take a good 5 minutes to get there could this still be an earth
Old Aug 30, 2007 | 07:44 AM
Blakeya's Avatar
Blakeya
Highly likey that the sensor is fugged. Before replacing though, remove the connector & clean using a suitable cleaner & maybe a little wet & dry or small wire brush. Replace connector to see if it makes any difference.
Andy
Old Aug 31, 2007 | 07:04 AM
turboben's Avatar
turboben
i have changed the temp sensor first and it did not work i even put a new connector on it
Old Aug 31, 2007 | 07:26 PM
SafeChav's Avatar
SafeChav
I can't see it being a short if it takes time to progressively work its way up. If it was the gauge would be up there in the red in about 20 seconds tops. I bet if you unplug it from the sender it doesnt move right - so theres no way it could be a short.
Which sender have you got? Round terminal or flat terminal?
Old Aug 31, 2007 | 09:45 PM
turboben's Avatar
turboben
spot on if i disconnet it then it drops down the sender is exactly the same colour as the old one which worked fine its a round terminal one
Old Sep 1, 2007 | 05:28 PM
Moonie's Avatar
Moonie
If it drops when disconnected and rises when earthed then i would say the electrical circuit is ok.
Have you got the thermostat in the correct way round?
Old Sep 1, 2007 | 10:08 PM
turboben's Avatar
turboben
yes the thermostat is fine the engine is not even getting hot and the fan kicks in normnal time about 10 minutes after running i just cant work it out
Old Sep 1, 2007 | 10:52 PM
gup's Avatar
gup
is it a new senser and where did you get it from fella
Old Sep 2, 2007 | 12:29 AM
turboben's Avatar
turboben
brand new
soverigns in harold hill i have a account with them
Old Sep 2, 2007 | 02:27 PM
SafeChav's Avatar
SafeChav
Your guage could be knackered.
Now being a series 1 it SHOULD have a flat terminal sender in there, ive read various stories about the later senders not working properly with the early instruments.
On one of my old mk1 orions i had a round terminal sender and that worked fine though, but for the few £ they cost i would get the proper sender and try that first, if not it must be your gauge.
Old Sep 2, 2007 | 03:28 PM
turboben's Avatar
turboben
its got to be worth a try but both the old and new one is a round terminal but as you said for what it costs might as well give it a go
Old Sep 2, 2007 | 04:04 PM
gup's Avatar
gup
alright fella if you pop round my house ive got the one i took off my old head you can try if not can you bring the car round so i can have a quick look at it
Old Sep 2, 2007 | 04:28 PM
gup's Avatar
gup
try putting a new wire from the senser to the back of the cluster as it could be the wire is too corrided causing high resistance fella
Old Sep 2, 2007 | 11:10 PM
turboben's Avatar
turboben
i am going to run a new wire some point this week if no luck then i will bring it to you
anyone know which wire it is, save me searching for it
Old Sep 3, 2007 | 10:14 PM
SafeChav's Avatar
SafeChav
yea its the wire you are plugging onto the sender
Old Sep 3, 2007 | 10:31 PM
gup's Avatar
gup
pmsl
Old Sep 3, 2007 | 10:32 PM
gup's Avatar
gup
cool beans fella give us a ring first fella i might not be in
Old Sep 3, 2007 | 11:12 PM
SafeChav's Avatar
SafeChav
pmsl
pfffffft kids eh
Old Sep 4, 2007 | 06:27 PM
turboben's Avatar
turboben
comedian
what wire which goes into the instrument cluster
Old Sep 4, 2007 | 09:38 PM
gup's Avatar
gup
if you look at the back of the clocks you can trace the wire back to the pin on the clocks
Old Sep 5, 2007 | 11:02 AM
turboben's Avatar
turboben
so its the same colour as the sender end
Old Sep 5, 2007 | 05:54 PM
Billy_RS's Avatar
Billy_RS
Sounds complicated
Old Sep 6, 2007 | 10:29 AM
SafeChav's Avatar
SafeChav
Originally Posted by Billy_RST
Sounds complicated
doesn't it just
Yes the wire will be the same colour all the way through the loom. Off the top of my head im pretty sure its a Red/White wire.
Old Sep 6, 2007 | 08:46 PM
turboben's Avatar
turboben
yes its a red and white wire and it splits into 2 at the clocks and goes into differnt parts in the connector does anyone know why??????
does anyone have a wiring diagram for the back of the clocks to show what does what
cheers
Old Sep 8, 2007 | 05:37 PM
SafeChav's Avatar
SafeChav
it does what
Sounds like the wiring that end is the problem that wire shouldnt split off 2 ways
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
gingeRS
17
Oct 2, 2015 09:42 AM
Fiddy
21
Sep 29, 2015 06:10 PM
