Crank sensor gap
Old Aug 23, 2007 | 10:56 AM
65Cabby's Avatar
65Cabby
Default Crank sensor gap
1st post so I think I need to say hello first as I usually like to have at least answered a question on a forum before I post one but I don't think I will be too much help here.
I'm running a DTA fuel injection on a flat four engine but as it is now fuel injection I needed a hall sensor.
I'm using a Fiesta / Escort 6 crank sensor due to it long reach.
I've not have any crank errors at low or high rpm like a lots of crank sensor issues I read but it totally failed on me the other day. I checked the shielded wire etc and in the end bought a replacement. Luckily unlike some of the bosch units it was only £22 from a dealer.
I want to make sure that I have the correct gap so can anyone tell me what the gap should be for it. The part number is 6C 315 89BF-AC and from what I have read it was used on the Fiesta and Escort up to 99.
thanks
Richard
http://65Volkswagen.info
Old Aug 23, 2007 | 03:52 PM
I would try 0.8mm, but this is a guess as I do not know for certain, if it is too large or small you will soon know.
Old Aug 23, 2007 | 04:07 PM
scholes's Avatar
scholes
I also run dta and i run about a 1-2mm gap with no probs.
Old Aug 23, 2007 | 07:39 PM
65Cabby's Avatar
65Cabby
Thanks, I'll narrow the gap a little then because I'm must be at about 3-4mm
Old Aug 24, 2007 | 06:30 AM
3 to 4mm is way too much gap, just have a play with the gaps.
Old Dec 19, 2007 | 10:45 PM
mappindude's Avatar
mappindude
yes agreed as above .
sensor gaps needed vary from ecu to ecu .
Start from about 1mm i would.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
