Engine mounts?
Old Aug 21, 2007 | 08:15 PM
Moose's Avatar
Moose
Default Engine mounts?
What are the best engine and gearbox mounts to get? only seem to be able to find gearbox ones at the mo, what is everyone running on theres?
cheers
rich
Old Aug 21, 2007 | 08:34 PM
gus's Avatar
gus
i have vibratechnics on mine
no problems there
dont think anyone does a uprated engine mount, its just gearbox i think
Old Aug 22, 2007 | 06:19 PM
Moonie's Avatar
Moonie
As above, i also have Vibratechnics gearbox mounts.
These two mounts take most of the load, the other mount is just a support mount and im not aware of an uprated one. If yours is a bit tired then a new one from Ford will be fine.
Old Aug 25, 2007 | 01:20 PM
stevedb's Avatar
stevedb
I used Deflex mounts on my cab because i couldnt afford Vibratechnics ones at the time so i went for the cheaper option only i wish i hadnt as a bolt snapped after a couple of months. I was sent new stronger bolts from Deflex free of charge and have had no problems since but still wish i had bought the Vibratechnics mounts as they sound like they are far better quality.
Old Aug 26, 2007 | 09:29 AM
Fiecos Dan's Avatar
Fiecos Dan
i've broke vibra techinic's one's on my xr2tt,
now run my own spec items with out issue at all.
No vibrations like Vibra's, with less movent.
Old Aug 26, 2007 | 11:52 AM
Badman38's Avatar
Badman38
i run zoo motorsport custom group a spec mounts there is no give and loads of vibrations
thanks
sean
Old Aug 26, 2007 | 11:58 AM
Fiecos Dan's Avatar
Fiecos Dan
Sean,
are they solid mounts?
Old Aug 26, 2007 | 05:37 PM
Badman38's Avatar
Badman38
Originally Posted by Fiecos Dan
Sean,
they have got rubber inners but not much custom gearbox cradle
Old Aug 26, 2007 | 05:40 PM
gus's Avatar
gus
im on solid vibratechnics, not yet run on them yet but expect to lose a few fillings
if too harsh i will go back to the road vibra's
if they no good i will give you a shout dan (s1 gearbox i thank you )
SmudgerByName
52
Jul 28, 2016 06:14 PM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
lockie
Jul 31, 2015 10:03 PM
