<<<FINALLY BREAKING BIG SPEC SAPH>>>
2Evos & 1 Escort Van :-)
This car, the most unreliable Deer killing Cossie known to Passionford:
Everything on it is going. All of it via Ebay. Link to my stuff here:
http://search.ebay.co.uk/_W0QQsassZcossiesi
Anything not listed yet will be on over the next few days.
Basic spec- big brakes, 467 bhp coilovers, MOs, stainless shiny bits. Blah blah blah. Keep your eye on my items on Ebay.
Ask me if you want something but it's not listed. Whole car is going in parts. Engine and suspension components should be listed during the week.
Items sold already:
MT75 Mullit Gear box
Mocal Oil cooler
T4 turbo
Forge Header tank
Everything else available.
07971 661940 or Sib666@hotmail.com
Don't PM as my inbox is nearly full.
I'm open to BIG offers only. Otherwise the items will sell for whatever they sell for on Ebay. If you want to see any parts I'm in Yeovil, South Somerset. M5 Junction 25 is nearest motorway to me.
I can bring most parts to Croft if you want - or can post smaller items, and you're welcome to collect any of the larger items.
Si
Full spec:
H789 ETA Spec list
4x4 Sapphire Cosworth 1990
Engine:
2.0 YB Currently 467 bhp (with more to come)
200 Motorsport block
Big wing sump
Cylinder Head Developments 550bhp spec Cylinder head
BD 14 Inlet cam
BD 14 Exhaust cam, slight score on bearing face
Standard Exhaust cam
Kent VS 34 Valve springs
Piper vernier cam pulleys
Gates Powergrip cam belt
Cometic Rocker gasket
Cometic Inlet gasket
Denso Iridium spark plugs IK31 / 071s
Standard head bolts
Standard crank
Standard rods
All lightened and balanced
ARP Rod bolts
Cosworth 7.2:1 Pistons with valve cut-outs
Cosworth high pressure oil pump
2400 Motorsport turbo hanger
2wd Exhaust manifold, no cracks, tidy
2wd Exhaust manifold, no cracks, powder coated black and silver, will need stripping before use
JR Air filter, blue, not mint
T4 Turbo, 360 degree thrust, enlarged penny washer
Bailey turbo inline oil pre filter
Swedish style 2400 Motorsport inlet plenum
CHD Flowed inlet manifold
Siemens 83lb/hr fuel injectors
Siemens 72lb/hr fuel injectors
Coil pack conversion
Collins Engine mounts
044 Group A fuel filer
Forge Motorsport Header tank
Forge Motorsport Oil breather tank
Forge Motorsport Power steering tank
Forge Motorsport Swirl pot
Forge dumpvalve, gold
Spec R dumpvalve, silver
Radtec RS500 intercooler
Mocal 290mm 13 row oil cooler
Custom stainless exhaust 3” bore, 4” tail pipe
Samco boost, coolant and ancillary hoses
3 Bar map sensor
Stainless steel bolts and jubilee clips throughout
Stainless steel 2400 Motorsport bonnet stay
Stainless steel 2400 Motorsport throttle bracket
Stainless steel 2400 Motorsport map sensor bracket
Stainless steel 2400 Motorsport lower radiator pipe
L8 ECU Live mapped byStuart Sanderson, Motorsport Developments
Air injector single type
Transmission
Big tooth straight cut Mullet spec MT75 box with uprated (60Nm) VC
Big tooth rear diff (uprated planet gears), brand new bearings and seals, uprated (150Nm) VC
Standard front diff, 2400 Motorsport diff strengthening plate, brand new bearings and seals
XR4x4 Front drive shafts
Alcon 6 paddle clutch
Alcon heavy duty cover
New standard release bearing
Lightened flywheel
Prop bush donut
Gear lever cradle
Suspension
Avo coilovers, 400lbs front, 200lbs rear, lowered 42mm
Deflex polybushes all round, except Esc Cos rear beam mounts
24mm Escort Cosworth rear anti roll bar.
Compbrake rose jointed Adjustable track control arms set to 2 degrees -ve
Brakes
Front: Compbrake 330mm x 32mm grooved Powervane rotors and bells
CompB4 4 pot Pro Race 1 Calipers, Hawk Performance HP Plus pads
Goodridge braided brake lines, Dot 5 brake fluid
Rear: Compbrake 300mm x 20mm Powervane rotors and bells
Spacer bracket mounting standard 4x4 rear callipers, Ferrodo DS2500 pads, Goodridge braided brake lines, Dot 5 brake fluid
Wheels and tyres
4 x Compomotive 5 spoke white MO 17” 7.5J ET35 wheels Toyo R888 205/40/17 tyres
5 x Compomotive 6 spoke white MO 18" 8J ET32 wheels
Alessio multispokes 17” 7.5J ET35 wheels Yokohama A520 205/40/17 tyres
Body
4*4 Bonnet complete with grills
Saph boot lid with spoiler
Morette quad headlights, pair in red, silvering average
Morette quad headlight, passenger side only, in bare ABS plastic
3 pairs of Clear front indicators
Smoked side indicators/ repeaters
Laguna front splitter
Interior
SPA Dual digital gauges for Oil pressure/ oil temp, water temp/volts
30 psi Boost gauge, white face black bezel
Charge air temp gauge
Momo Race steering wheel & boss
Escort Cosworth gear knob
Speedo cluster with Lockwood white dials
Ice
JVC 4*50w CD Headunit, JBL 6.5” Components, 6” Coaxials on rear shelf, some random amp!
Items sold already:
Mocal Oil cooler
T4 turbo
Forge Header tank
Si
Full spec:
H789 ETA Spec list
Engine:
Big wing sump
BD 14 Inlet cam
Standard head bolts
Standard crank
Standard rods
ARP Rod bolts
3 Bar map sensor
Transmission
Lightened flywheel
Prop bush donut
Gear lever cradle
Suspension
Brakes
Wheels and tyres
Body
Interior
Ice
I'll be listing the hoses on Ebay tomorrow evening or Tuesday night latest Brian - I'm not sure what I've got at the mo.
Virtually all my hoses were Blue SFS or Roose ones - but until I go through the pile I'm not sure what they are like.
Will update this post daily with new items listed.
Si
Si
Si
Si
READ THIS PLEASE EVERYONE!
NO PMs please - my inbox is nearly full. EVERYTHING pretty much will be listed on Ebay - bid on there please.
Sorry to those bidding - EBay removed 40 odd ads that took me 8 hours to photo, and describe/ list
I made the mistake of putting that there was no Buy it Now, but make an offer. OOOOPPPPPSSS - they don't like that.
Trying to get ads reinstated now, otherwise I'll be relisting everything next weekend as I don't have time during the week to do it.
So, to conclude:
NO PMS please.
IT WILL ALL BE ON EBAY.
NO BUY IT NOWS.
NO OFFERS.
Sorry, got to keep it fair for everyone - I've had so many PMs about brakes / wheels etc. Can't do one thing for one and one for another. I'll update this post as soon as I know if they will reinstate my 8 hour listing spree. I'll also update it when I know what's on there and what's to go on there.
Hope you all understand, sorry again
Si
So, to conclude:
NO PMS please.
NO BUY IT NOWS.
NO OFFERS.
Si
Originally Posted by cossiedave
iv tryed buying parts off sib but no joy as he is stubborn to give a price
Hence this time round, everything will be on EBay, if you want something, bid for it on there please folks.
Si
Originally Posted by bud-weis
Is the engine the same one that had 1 liner fitted? or is it a different block?
The liner is fine, and is a good way to rescue an otherwise mint block.
Si
Originally Posted by cossie604
The inlet plenum being listed seperate or complete with engine when it goes on fleabay chap??
Stu.
Stu.
The plenum will be going seperately
The whole engine will also be broken into it's individual parts as well> so crank, rods, block, oil pump, water pump etc etc.
Si
Hi Stu,
Si
Will keep an eye out then chap
like what if you mean the oil cooler i could not even get Ł90 for it as the sandwich plate had a split in it so sold it for Ł40 so i lost Ł50
Just to reiterate what is written SO many times everywhere:
DO NOT PM for parts please, everything will be on EBay by end of August!!
I will update this post as soon as the items are relisted- having had 8 hours work deleted by the CU~*Ts at Ebay, I've not had a chance to get relisting them yet.
No prices. No offers. No PMs. To keep things fair to everyone, it will all go on Ebay, and you can bid as little or as much as you want.
Weirdly, the 3 items left on Ebay all should have been deleted by them when they took the rest of the stuff off, but they left them
Anyway, WHEN the items are all listed, I will update this post to say so.
Ta
Ta
how much are the morette twin headlights mate, aslong as there in good condition and not cracked etc and with working lenses etc and in good condition with post to london heathrow.
cheers
cheers
Quads have sold - they were one of the only items Ebay didn't delete for some weird reason.
NO MORE REPLIES TO THIS THREAD FROM ME UNTIL THE ITEMS ARE RELISTED ON EBAY. I WILL BTTT THIS THREAD WHEN THEY ARE RELISTED.
DO NOT PM ME, NOTHING IS FOR SALE AWAY FROM EBAY
Ta
Ta
