Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
16i fuel relay
Old Aug 14, 2007 | 04:35 PM
japslayer's Avatar
japslayer
Default 16i fuel relay
I have posted a thread in the Q&A section but getting very little response, i need the seimens relay to replace mine which has given up, does anyone know the part number? iv heard that the MK1 golf had the same relay and can be bought from VW but VW are as much help as a chocolate tea pot without part numbers or reg etc
Old Aug 14, 2007 | 05:02 PM
GraphiteGray's Avatar
GraphiteGray
I been told VW have discontinued the fuel pump relay so that may be why you havent had much luck
you can still get them from GSF car parts for around £30 inc delievery
go to http://www.gsfcarparts.com/ and click on the online shop, the part number for the relay is 93590
apparentley they can do two types, one with the original fuse and another which has a later type blade fuse fitted at the top
Hope that helps
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
20/20 vision
Sep 29, 2015 11:27 AM
