help needed,whats this called?
Old Aug 7, 2007 | 02:06 PM
banhambuilt's Avatar
banhambuilt
Default help needed,whats this called?
need some help please
my air con fan on the bmw has stopped working
getting power to the fan but it isna`t spinning,on stripping down there is this 10 of these connectors
the main motor plugs into the connector and the connector is held in a plastic sleeve and push`s onto a copper wire.
it is roughly a 5mm male connector and the bottom hole that push`s onto the copper wire is roughly a 1mm slot.
anyone know where i might be able to get some from or even what they are called?
tried google but can only find normal push on connectors.
thanks for your help
dave
Old Aug 7, 2007 | 02:10 PM
dojj's Avatar
dojj
Resident Wrestling Legend
is it a spade connecter you are afer then?
Old Aug 7, 2007 | 02:49 PM
foreigneRS's Avatar
foreigneRS
Testing the future
sounds a bit odd
i would look into doing it better than original - solder or whatever
Old Aug 7, 2007 | 03:13 PM
banhambuilt
it is a spade connector of sorts but it locates a copper wire at the bottom in a plastic sleeve and a female connector from above above,can`t really attach a seperate wire instead of this as motor will be spinning very very close to it,can`t be sure wire wont catch
Chas
Sep 21, 2015 08:57 PM
cos elle
Sep 1, 2015 06:48 PM
Bailes1992
Aug 16, 2015 07:14 PM
col93saphcos
Aug 7, 2015 03:21 PM
