whats the most annoying jobs to do on your ford?
just wondering really, what would you say is the most annoying and frustrating thing to do, fix or replace on your ford? or any other car in general?
anythinkg on a b*starding peugeot... its all star keys and strange sizes...
anything on a ford is easy compared... took me and a mate about 2 hours to replace both wishbones, steering rack & track rod ends about 2 hours to do... took me and him 7 hours to replace the front springs on my 106...
Originally Posted by m4dyeti
cvh sump gasket........
hardest job known to man
Originally Posted by twinkle_2k86
heater matrix
and have to say, CVH sump gasket as well, piss easy to do, Fooking impossible to seal
bastard, i have to put mine back on soon
Tell me about it, I did mine 3 times last week
T.W.A.TING thingI ended up using this stuff on both side of the gasket and worked a treat, it's like rubber when it goes off, But i did leave it 24 hours before putting oil in.
Cost about Ł4.
on the sierra the clutch ratchet, the steernig column bush, heater matrix and the rack on a 4wd car tend to big bastard jobs
the only thing worse is the pin on th ebox on the 4wd cars as it's quicker to drop the box
on the mondeo, it's everything
Originally Posted by jonsmiff
if you glue the half moon seals in on a cvh gasket then they dont dislodge when you refit the sump and piss oil all over the place,works every time
served my time in a ford rs dealer 89 - 94 so you could say ive done a few, this was how i was taught how to do the sump on rs turbo,s, the inner gasket that is near clutch/flywheel would sometimes get dislodged when refitting the sump due to the angle you have to push it in at when the engine is still in the car, glueing this in stops that happening.
Originally Posted by GINGExR2 T
paceo Use the stuff i used, as looking at your sump it'll be a 1 piece black rubber gasket, not the early 4 piece 2 cork, 2 orange rubber type.
did you only seal the half moon sides on the end?
no matter which gasket you use, still put glue on the inner part
Sierra
Clutch Pawl.
Spigot Bearing loads of grief to replace a Ł5.00 Part ( as in box out, clutch e.t.c)
Heater Matrix is just a bit of a pain.
On a Mini
Mechanical Fuel Pump
Clutch Pawl.
On a Mini
un seizing mk2 fiesta back breaks because my brother is currently trying to do one up and he only looks at it once every 6 months and i have to loosen them every time
and mk4 golf electric windows and locks its that stupid metal panel that everthing is attached to that is a right coont
