Q for mike r or other suspension peaps...
i have this forge strut brace for my 4x4
now i really like the fact its chunky as fook and i like the design near the ends but will it actually work properly?or am i better off buying a different one that will work properly?and ebaying mine
reason i ask is i looked at a few at ford fair and obviously mikes one and see alot of these ones.
and i know mike knows his shit so thats why he has one.
Providing you use the correct bolts and not three self tappers
, then it will be fine - not ideal, but perfectly acceptible
, then it will be fine - not ideal, but perfectly acceptible good to see your car up and running mike,look forward to seeing her back on track. i see harvey was out taking in what was about yesterday.didnt think he did shows anymore.
Ideally it would be braced against the inner part of the turret, with the other side of the turret welded as in the pic to the inner wing.
But as it is a road car it will be more than enough.
I don't think on a road car you will notice a significant difference between the two designs - PROVIDING you used bolts like you suggested
Obviously the braced method is better, as it is not just relying on the rigidity of a few bolts
SMILER258
Sep 28, 2015 09:04 AM
