General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
i have an escort cosworth just been a pain in the ass from the word go but finely finished. The only problem is if i drive it hard through all the gears its fine ,but if i am at say 3000 rpm and in a high gear say 3rd 4th or 5th and go to pull it just coughs spullteres and u here turbo chatter DOES ANY BODY NO WHAT WOULD CAUSE THIS AS ITS DOIN MY HEAD IN AAARGH
ANY IDEAS PEOPLE THANKS
NOT SURE ABOUT WHAT PLUG NUMBERS BUT ITS T38 GREYS CAMS ETC AND HAS HAD ALL SENSORS AND SWITCHS CHANGED. APPART FROM TPS WHICH I HAVE AND IS READY TO GO ON SO IF IT IS TPS HAPPY DAYS.WHATS THE IDEAL PLUGS FOR THIS SPEC I WAS TOLD MOTORCRAFT ARE AS GOOD AS ANY
does a bigger gap give a smaller or bigger spark?? ive had my gaps at 0.88 and now 0.75 and still cant find the correct gap either as im having the same sort of problems when using boost.
