Freshly Rebuilt 4x4 Engine (200 block) SOLD
Old Aug 5, 2007 | 02:30 PM
silky16v's Avatar
silky16v
Get on That!
Default Freshly Rebuilt 4x4 Engine (200 block) SOLD
Right this is my Engine out off The E30 Cosworth
Just to add this engine is from a late spec 4x4 saph with lambda (Green Top Rocker Cover) Green Sticker on L8 ECU
Ford Cosworth YB (200 Block) Engine Producing 361bhp, 354ft-lb Torque (Dyno Proven). on a MSD stage 3 conversion
The Engine has undergone a full engine rebuild Done 1700 miles (including 1000 running in miles) all parts where purchased via Matt Lewis Motorsport which included:
• -0.5mm Mahle Pistons
• 5 bar high pressure oil pump
• Big-End & Main Bearing (std size)
• ARP Big-End bolts
• Group A Head Gasket
• 16 valve guides & seals
• Cylinder Head was pressure tested and measured (138.92mm) had all valves lapped in using 3 angle valve seats, new camshaft bearing & seals
• New Gates Cambelt & Tensioner
• Freshly Painted Rocker Cover
• All new gasket and bolts where used
The engine is fitted with a 2wd sump, and the unions for a oil breather kit (as seen in Pictures)
Please note this is for the complete Tall Block Engine & WILL NOT include:
Inlet plenum, Turbo & Manifold, Thermostat housing, PAS pump & Alternator.
However it does include: AP 6 paddle Clutch, cambelt cover, engine mount arms & brand new coolant temp sensor
All other parts from the engine are being sold seperatly
For the engine complete
£2000.00
For Genuine Interest Please CALL ME: 07725 106612
Please DON'T send endless Emails & PM's when a quick phone call can answer all you questions in 1 go
Here are some Photos
Old Aug 6, 2007 | 04:31 PM
rosscoe's Avatar
rosscoe
Default parts
alright m8
would you sell the prop and box for an e30 conversion,quite fancy an e30 cossie
Old Aug 6, 2007 | 06:57 PM
pieterjan's Avatar
pieterjan
Hi would you sel the SPA gauges?
Old Aug 8, 2007 | 09:22 AM
silky16v's Avatar
silky16v
Get on That!
Default Re: parts
Originally Posted by rosscoe
alright m8
these items are being sold with the shell sorry
Old Aug 14, 2007 | 11:46 AM
silky16v's Avatar
silky16v
Get on That!
Updated some parts have been sold with the BMW shell
Old Aug 14, 2007 | 11:58 AM
Sticky.'s Avatar
Sticky.
Any news on what we talked about Matt
Old Aug 14, 2007 | 12:02 PM
silky16v's Avatar
silky16v
Get on That!
still thinking about it mate i'm waiting to hear back on a Kit Car project that i fancy slotting this lot into
Old Aug 14, 2007 | 12:06 PM
Sticky.'s Avatar
Sticky.
Ok matey...keep me informed if you do decide to sell
Old Aug 14, 2007 | 04:31 PM
Brocker's Avatar
Brocker
'I can need the turbo if you will sell it alone
Old Aug 14, 2007 | 05:31 PM
tregmatt's Avatar
tregmatt
hi mat how you
Old Aug 14, 2007 | 06:55 PM
silky16v's Avatar
silky16v
Get on That!
Originally Posted by tregmatt
hi mat how you
doing ok mate, be better if someone bought the engine
Old Aug 17, 2007 | 10:10 AM
silky16v's Avatar
silky16v
Get on That!
Bump! Tall Block Engine
Old Aug 17, 2007 | 12:47 PM
Shorty's Avatar
Shorty
You keeping the rest of the bits mate?
Old Aug 21, 2007 | 03:26 PM
silky16v's Avatar
silky16v
Get on That!
Bump
Old Aug 25, 2007 | 12:24 PM
silky16v's Avatar
silky16v
Get on That!
upski
Old Sep 2, 2007 | 07:47 PM
silky16v's Avatar
silky16v
Get on That!
bump!
could the guy who rang me today could you PM your details as i've lost your number
Old Sep 2, 2007 | 08:29 PM
e30hass's Avatar
e30hass
hi will you sell the turbo?
if whats the spec on it
thanks
Old Sep 3, 2007 | 09:05 AM
silky16v's Avatar
silky16v
Get on That!
thanks
Turbo sold
Old Sep 6, 2007 | 03:48 PM
saph4be's Avatar
saph4be
is engine still avaiable
Old Sep 12, 2007 | 10:56 AM
silky16v's Avatar
silky16v
Get on That!
Deposit taken
Old Sep 16, 2007 | 11:09 AM
silky16v's Avatar
silky16v
Get on That!
SOLD
carlo
24
Oct 5, 2015 08:20 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Aug 17, 2015 09:06 PM
Aug 12, 2015 10:03 PM
Bart
Aug 9, 2015 09:04 AM
