How much power can a t34.48 give ?
saff is working!!!...atm
i suppose it depends on which R/R.......but i've done 357 on greens and my pal did 363 on greens............he now has l/blues but the car (2wd) wouldnt stop spinning.............the dyno operator guessed at 380ish.....regardless its a fookin' mint turbo......
Kev, my old 3dr made 363/360 torque @ 2.1 bar..with a .48
Loved that setup, very responsive..
.63 housing will give you that bit more power, but will be SLIGHTLY laggier..
low 300s tops IMO
Originally Posted by pete mcrash
low 300s tops IMO
Euans not tight....
Originally Posted by tabetha
377 was on an engine dyno, was a test engine and repeated same power at least 30 times, over 3 days component testing, so was accurate.
NB it was not quite up to max out power either.
My t34.55 was wrung out at about 300 ATW so at most 350 fly.
A t34.63 could do 400.
A t34.48 will be flat out over 300 fly.
Maybe Im wrong but I can only go on cars I have seen
its airflow that the turbo can produce thats the limit for bhp.
Originally Posted by KSA-Cossie
Think i'd be better with siemens blacks than greys pete ?
I have Greys on the saff at present (NOT MY DOING THOUGH) They were already on, i'm putting some 1000cc in though, the greys are nearly dying at 430bhp..
The figs Im on about are for a pretty much standard engine like Kevs.
look at my sig..............standard head ut t38.............made 420 at well lane....not at full boost either, Ava is ment to be the best for "on the road " conditions............
on the rollers it held 26psi..................on the road it holds 27/28psi......and yes its mapped by Ahmed....i've also put an airbox back on and improved the cold air flow............
I "guess" that it will make 330-340 ATW on a cold day
when you thinking about coming?
Originally Posted by Lambchop
my .48 made 272@wheels@ava. when i finally get this new bastard engine working with my new 500 ic id like 280-285 odd.
