Where can i get these power steering pipes (4x4)
I have been told ford don't make them anymore
Not that bothered about the long metal one as that can be replaced with a hose if necessary, but the one that goes from the rack to the pump i think i will have to get that exact part. Also, is that specific to cossies or does an XR or a 4x4 ghia have a similar part?
usually PAS systems have a long metal pipe to get rid of some heat - replacing it with hose is not a good idea
don't know if the 4x4 system has another pipe to act as the cooler in addition to the long one pictured
foreigneRS
yes it does
the 1st pic is just where the pump gets fluid from, it then goes through the 2nd pic into the rack
out the rack and goes toa cooler pipe on the passenger inner wing and back to the bottle
rog the bottom one, take it to a hydraulics place who make pipes etc, they may be able to mae you one
yes it does
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
