tremec gear box tk 3550 will it suit a cosworth ratio wise
tremec gear box tk 3550 will this suit a cosworth engine & ratio wise can any one work it out please
1st 3.27
2 1.98
3 1.34
4 1.00
5 0.68
1st 3.27
2 1.98
3 1.34
4 1.00
5 0.68
That 5th gear is no good whatsoever even a 650+ Cossie cant pull it.
It will give you a theortical Topspeed past 214mph @ 7500rpm on 215/40/17
You can get a .83 5th gear for a TKO so I expect its available for the 3550 thats is within 3% of a T5 .
Below will give you the speeds @ 7500 on 215/40/17 using 3.64 diff
!st 45mph
2nd 74mph
3rd 109mph
4th 146mph
5th .68 214mph
5th .83 176mph
!st 45mph
2nd 74mph
3rd 109mph
4th 146mph
5th .68 214mph
5th .83 176mph
Originally Posted by escort700bhp
could u not use a 3.9 cwp with that to bring the gearing down??
!st 42mph
2nd 69mph
3rd 102mph
4th 136mph
5th .68 200mph
hi mate
1st gear is a bit short
2nd is ok
3rd is ok
4th is ok
5th is to low that a pure cruse gear
if you do go to a 3.9 1st gear will be even shorter not only that you will still struggle to pull the 5th gear
if you can go for ratios like 2.95 /2.97/3.00 for a 1st gear
2.10/2.07/2.00/1.94 for 2nd
1.50/1.45/1.4/1.35 for 3rd
1.1 for 4th
0.85/0.83/0.80 /0.77 for 5th dont really go much lower on 5th any of these ratios will be ok in a road car with the 3.64 or 3.62 diff
marco
2nd is ok
3rd is ok
4th is ok
1.1 for 4th
marco
steerfromdarear
28
Jan 29, 2016 06:14 PM
JPA
Nov 8, 2015 12:26 PM
Aug 14, 2015 07:29 AM
