On car Adjustable TCA's 4x4 Cos Pinch Bolt Type
Old Jul 28, 2007 | 01:06 PM
NUTS RuS's Avatar
NUTS RuS
Default On car Adjustable TCA's 4x4 Cos Pinch Bolt Type
Well over 60 pairs sold just on Passionford alone with NO comebacks yet.
Has to say something
New freshly converted arms, zinc plated adjusters, rose joints, side spacers, new bolts and nylock nuts all supplied in the kit.
£156.40 inc UK delivery
New TCA replacement cup washers available to complete the kit for £10 if purchaced with the TCA's
Washers available seperatly £12.50 per set
Old Jul 28, 2007 | 01:58 PM
dave cos4x4's Avatar
dave cos4x4
Hi Tony,
i will have a set,throw them in with the other bits.
thanks,
Old Jul 31, 2007 | 07:46 PM
space hoppers's Avatar
space hoppers
are these really good quality and are they good for a road car which occasionaly goes on track wot do i need as all of mine need replacing
cheers james, sorry i dont no to much about these
Old Jul 31, 2007 | 08:06 PM
NUTS RuS's Avatar
NUTS RuS
Are you suffering from any tyre wear on the edges James ?
They will help to reduce that, and also if you are into track settings you can set up the camber to what you want if the car is lowered (or sagging on old springs) etc.
If you are not suffering from tyre wear you could set them to the standard length for road use, and as they are fully adjustable on the car on your track day it is simple procedure to wind on a little camber for the day, then wind it off again at the end of the day before you go home. You then have the best of both worlds
Numbers sold against a zero comeback rate so far means people must be happy with the quality and price
There are two types available, the pinch bolt type (pictured above) where the TCA is held into the hub by a pinch bolt, or the nut and bolt type, where the TCA is held in by a nut on top. Just check which type you have as we make both
Old Aug 1, 2007 | 05:56 PM
space hoppers
thanks for the reply was told that my stanard ones are knackered when MAD boys took the engine out. which is stronger pinch bolt or other. i dont suffer outside tyre wear but want to make the old girl turn in sharper i am also running leda coilovers
thanks again james
ps are you at ford fair at all ?
Old Aug 1, 2007 | 07:13 PM
NUTS RuS's Avatar
NUTS RuS
Its not a case of which is stronger James, it depends on which hubs you have on the car as only 1 type will fit.
Not going to make FF this year sorry
Old Aug 2, 2007 | 10:06 AM
space hoppers
ok got ya will check to see and get back to you
Old Aug 31, 2007 | 11:26 AM
NUTS RuS's Avatar
NUTS RuS
3 more gone this week
Old Aug 31, 2007 | 11:36 AM
Sticky.'s Avatar
Sticky.
Old Aug 31, 2007 | 04:45 PM
ECOS95's Avatar
ECOS95
Got these off ebay a while ago but they are
Just got to get them fitted. Lol.
Old Aug 31, 2007 | 05:02 PM
NUTS RuS's Avatar
NUTS RuS
I probably sent them out to you But you would have paid direct to the office for them
Old Aug 31, 2007 | 05:17 PM
Kelv's Avatar
Kelv
Almost there!
Tony, can you replace the lower ball joint rubbers, i pinched one of mine when i stripped the car down
also im heading back up monday for 10 days, cash in hand for the other goodies aswell, if thats still ok?
Old Aug 31, 2007 | 05:28 PM
NUTS RuS's Avatar
NUTS RuS
You can buy them on Ebay for about £6 for 10 Kelv.
http://cgi.ebay.co.uk/10-Larger-Trac...QQcmdZViewItem
That should give you a fair go at swapping it and getting it right, or there is a bloke on here selling the same ones in the for sale forum for about £6 for 2 IIRC
Wednesday at the Peskyrat Manor would be fine if you can make that as I dont want to take your discs out of the de humidified room until the last minute as they start to oxidise. Thats not a problem as it cleans off but it just looks unsightly
Old Aug 31, 2007 | 05:34 PM
Kelv's Avatar
Kelv
Almost there!
is it this wednesday - sounds good to me. still working out when each meet is
Old Aug 31, 2007 | 05:52 PM
NUTS RuS's Avatar
NUTS RuS
If not we can invent a new one somewhere
Old Aug 31, 2007 | 06:36 PM
Sticky.'s Avatar
Sticky.
Next meet is 2 weeks guys....we've had a 5 week month.
Old Aug 31, 2007 | 06:39 PM
Kelv's Avatar
Kelv
Almost there!
what Date is it Paul?
Tony, ill pop up and see you during the week if thats the case - can give them to my mate to have bits annodised and fitted to the beam ready for when i get home next time!!
Old Aug 31, 2007 | 09:21 PM
NUTS RuS's Avatar
NUTS RuS
No problem. We can sort something out no doubt.
Old Sep 1, 2007 | 07:05 PM
Sticky.'s Avatar
Sticky.
2nd Wed on this month Kelv
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
track.focus'd
Aug 12, 2015 05:53 PM
xr4x4rs
Aug 6, 2015 09:03 PM
bassboy
Aug 5, 2015 08:21 AM
Bosch
Aug 4, 2015 05:14 PM
