quick ICE amplifier question
Old Jul 28, 2007 | 09:01 AM
gordyshreds's Avatar
gordyshreds
Default quick ICE amplifier question
Hey, morning all, just wondering, if on a head unit i have the front and rear speakers powere by amplifiers, i.e both RCA outputs are used, does the headunit still produce output through the normal speaker outputs?
i'm planning on my van to have 2 seperate sound stages, in the front i want to have 4 speakers, powered by the headunits f+ outputs and 4 speakers in the back powered off the headunits rca outputs
cheers
Old Jul 28, 2007 | 09:02 AM
Mark 3D's Avatar
Mark 3D
Moderator
I think that is possible but I also think you may be over working the head unit doing that!
Old Jul 28, 2007 | 11:42 AM
bluescortcossie's Avatar
bluescortcossie
the head unit will carry on powering the normal (high) outputs through its own amplifier but you will find the rears will drown them out and they will also distort much earlier that the amped speakers , much better to get another amp just for your fronts and then it can be setup to match what you want without loads of nasty flapping noises at high volume
Old Jul 29, 2007 | 07:42 AM
StephenC's Avatar
StephenC
..BS Motorsport..
always thought simpler was best with ice, nice set of components up front and then just bass from the rear. The best car I ever sat in had only 5 speakers, 2 in each door (5 1/4" components with tweeters) and a 10" sub in the back. Speakers in the rear other than bass just fucks around with the sound stage, you dont go to a concert and turn your back on the speakers, you expect sound to come towards your front which is what you should try create in the car. Bass speakers can be put anywhere as you feel bass more than hear it. Just my 2p worth.
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
