fao braided hose ppl
Old Jul 27, 2007 | 09:32 PM
Gary Osborne's Avatar
Gary Osborne
Default fao braided hose ppl
i was just wondering if anyone has made their own
brake lines before? was it a success first time round?
sitting her stressing about a fitting coming off a pipe etc.
if it dont leak the first time its pressurised does it mean its gonna be ok for ever.
wont know til next week but i dont need a problem as my fuel and oil cappilaries are made the same
Old Jul 28, 2007 | 03:59 PM
Gary Osborne
Old Jul 28, 2007 | 04:32 PM
THE RADMAN's Avatar
THE RADMAN
yep i made mine,being a plumber prob helps i got all my gear from think auto, you can make them exactly to what length you require then,plus its a fair bit cheaper,just make sure you get the olive on properly and dont get any strands of overbraid stuck underneath it,its easy
Old Jul 28, 2007 | 05:00 PM
Gary Osborne
i put them on fine i think . are you supposed to trim the strands right to the bottom of the olive or can you leave them run up the outside of it a bit?
seems to tighten up a bit better when you leave them run up the side of it.
mine are goodridge i think
Old Aug 3, 2007 | 01:13 PM
Gary Osborne
also does any one know if they rear braided line will get mega hot on track as its running beside cables etc in the car.
Old Aug 3, 2007 | 02:48 PM
dojj's Avatar
dojj
Resident Wrestling Legend
braided is easy to make, you just need to be methodical about building them up and making sure the olive is right and the braid is tucked up right too
and make sure you get thr right hose for the right application, or if you are doing more than one run of hose for brakes and oil and stuff, buy one lot and get that done first before you make the other lot up
and no, they don't get hot as far as i could tell, but i didn't put my hands near them when i went on track
Old Aug 3, 2007 | 04:11 PM
THE RADMAN's Avatar
THE RADMAN
no need to trim as long as theyre not caught underneath
Nov 1, 2015 06:53 PM
