are all cosworth ecu casings the same?
Old Jul 27, 2007 | 06:35 PM
M K's Avatar
M K
Default are all cosworth ecu casings the same?
i have had an ecu holder made but my ecu wont fit in it
i have a p8 ecu and the pressed out pattern on the metal casing is causing it to jam halfway in the holder so did the l8/l6 ecu's also ave the pattern or just plain casings as thats what i need to make it fit or il have to just make new sides from alloy sheet but that wont be as nice fitting as original on the edges
heres the pattern on the p8 ecu im on about thats causing it to be tight
any othe casing options
Old Jul 27, 2007 | 06:51 PM
The DIVA's Avatar
The DIVA
All the same mate........the pressed out bit is to give the lid strength...
Old Jul 27, 2007 | 06:57 PM
xr4x4rs's Avatar
xr4x4rs
and the 2wd ones had extra lugs on them as they mounted behind dash and not behind glovebox
Old Jul 27, 2007 | 07:00 PM
M K's Avatar
M K
ok cheers guys,
il have to make my own new side casing then
Old Jul 28, 2007 | 05:33 AM
It is only thin aluminium, put it on a flat bit of metal like a vice square and hammer it out very easily.
I have just done a chip change in mine and could swear it was flat(L6), maybe just getting old!
big_Rad
Sep 15, 2017 09:36 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
James Porter
Aug 14, 2015 12:43 PM
Aug 14, 2015 07:29 AM
