rasing idle on 4wd cossie
ok
is there anyway to raise the idel on a 4wd cossie by not adjusting the tickover screw as its seized solid and is round the centre
i know i have to raise my fuel pressure as its too low will this increae the tickover?
if nto any other ideas or is it a throttle off and having it drilled out and a new screw fitted
looks like a throtlle body off job then
sod it ill book it in somewhere and let them have the grief as at the minute i just want to scrap the thing with the problems its caused me this week
Had this trouble on my old 4x4
Put a second hand throttle body on it off a 2wd,the base idle screw is a different design,its got a lock nut rather than being a tight fit inside throt body
Roosie
thanks mate but im not looking at buying another throttle body just yet
ill have a tinker about with mine first and see if i can get the screw out
if i cock it up ill pm you lol
Russ Payne
Sep 25, 2015 08:29 PM
