slapping noise?
Old Jul 26, 2007 | 02:38 PM
R5FORD's Avatar
R5FORD
Default slapping noise?
my car used to run stage 1.. now iv changed to greens, 3 bar, t34.48, and gone closed loop.. im getting a sort of slapping noise from the injector/manifold.. could this be the extra fuel that is being forced through by the greens?
the car is going to be tuned tomorrow..so if anyone could tell me what it could be..would make the tuners life easier
cheers
Old Jul 26, 2007 | 10:01 PM
R5FORD's Avatar
R5FORD
any one??
Old Jul 26, 2007 | 10:04 PM
mechanic28's Avatar
mechanic28
slapping noise???
Old Jul 26, 2007 | 10:13 PM
R5FORD's Avatar
R5FORD
yhep its like a tapping noise now lol its quiet fast and when i take the lead of the idle control valve it stops
Old Jul 26, 2007 | 10:16 PM
mechanic28's Avatar
mechanic28
hmm well thats abit strange have u put a chip in to run your dark green injectors?
Old Jul 26, 2007 | 11:27 PM
R5FORD's Avatar
R5FORD
yhep..got the clkosed loop from stu..stage 3 chip
Old Jul 26, 2007 | 11:29 PM
Kevin Sharp's Avatar
Kevin Sharp
the slapping noise is an echo of the tuner spanking your arse bfore he gives you the bill
Old Jul 26, 2007 | 11:30 PM
R5FORD's Avatar
R5FORD
lmao
also the car is idling at 1500rpm
Old Jul 26, 2007 | 11:39 PM
Billabong's Avatar
Billabong
I think you may have found the problem then....
Old Jul 26, 2007 | 11:52 PM
R5FORD's Avatar
R5FORD
how di i turn idle down
Old Jul 26, 2007 | 11:53 PM
R5FORD's Avatar
R5FORD
however it still makes the knocking noise when i was driving
Old Jul 27, 2007 | 05:47 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
If you leave the car alone it will make the tuners life easier,let the tuner sort it for you,I doubt your diy is of any help to your tuner
Old Jul 27, 2007 | 07:06 AM
R5FORD's Avatar
R5FORD
well the tuner was stumped so i rebooked for monday..
however the noise is more of a chattering noise now and only does it when the idle control valve is on..when the valve is on its idling at 200rpm.. and when i take it off it idles at 950 and the chattering noise goes even when i rev the engine..
need to get this sorted
Old Jul 27, 2007 | 07:18 AM
Disabled Account's Avatar
Disabled Account
I think you've got a plenum air leak. Check the pipe that does to the newly installed 3 BAR MAP sensor, and also check all the other plenum connections/pipework.
Old Jul 27, 2007 | 07:31 AM
R5FORD's Avatar
R5FORD
il try that mate..
as iv upgraded to closed loop does i have a diffrent idle control valve?
Old Jul 27, 2007 | 08:38 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
have you had to do the wire swap on the tps sensor? if your car did not have a L8 wiring loom?
Old Jul 27, 2007 | 08:43 AM
R5FORD's Avatar
R5FORD
whats the best way to check for air leaks in the pipe?
Old Jul 27, 2007 | 08:45 AM
R5FORD's Avatar
R5FORD
wire swap? i havent changed no wire around on the tps sensor..was i ment to ?
Old Jul 27, 2007 | 08:52 AM
JTECH James
Passion for Fords!
did your car have an L8 ecu? ie 2wd or 4x4
Old Jul 27, 2007 | 08:58 AM
R5FORD's Avatar
R5FORD
had a 2wd oiginally then went closed loop so had to change to 4x4
Old Jul 27, 2007 | 09:00 AM
JTECH James
Passion for Fords!
so if your car still has the 2wd engine loom and a 4x4 L8 ecu you will need to swap the two outside wires on the tps, and fit a 4x4 tps
unless this has already been done? the pins simply come out of the plug at the tps end.
Old Jul 27, 2007 | 09:01 AM
JTECH James
Passion for Fords!
as the tps and iscv are linked so the iscv opens when the throttle is open, it may well be working kind off...erm backwards
Old Jul 27, 2007 | 09:06 AM
R5FORD's Avatar
R5FORD
oo that could be in..iv got a 4x4 tps but havent changed the wires around..
so this is the problem as when the icv is on it sends a chatter and when it is off it runs perfectly fine..
however would this be the reason for it idling at 200rpm aswel?
Old Jul 27, 2007 | 09:07 AM
Nash's Avatar
Nash
Cake lover!
Just get the wires swapped around and then see if it still does it, odds on it will be fine. Just change one thing at a time then you will know where you stand.
Old Jul 27, 2007 | 09:08 AM
JTECH James
Passion for Fords!
most probably yes!
swap the two outside wires over so the center one stays put!
and let me know!
these are the only changes you need to make btw
Old Jul 27, 2007 | 09:10 AM
R5FORD's Avatar
R5FORD
so just swap the 2 outside ones and leave the centr one?
it pissed me off..a little minor thing like this delayed my setup
but cheers guys
JTECH James
Passion for Fords!
yep swap them as the 4x4 tps works the otherway around!
Stu would be proud of me.....MSD diagnostic specialist
Old Jul 27, 2007 | 09:28 AM
R5FORD's Avatar
R5FORD
i checked in the instructions it dosent say anything about changing wires..
but il trust your experince lol
Old Jul 27, 2007 | 09:31 AM
Disabled Account
You'd only reverse the wires if changing from Level 6 to Level 8 ECU.
Old Jul 27, 2007 | 09:40 AM
R5FORD's Avatar
R5FORD
level 6 being 2wd?
Old Jul 27, 2007 | 09:48 AM
Lo@der's Avatar
Lo@der
Passionford Thread Killer
yes
L 1 = 3dr
L 6 = 2wd
L 8 = 4wd
Old Jul 27, 2007 | 09:50 AM
R5FORD's Avatar
R5FORD
sorted..il give that a go tmrw..
cheers fellas
Old Jul 27, 2007 | 11:04 AM
IANS2RST's Avatar
IANS2RST
is the idle low or erractic with the idle speed control valve plugged in?
if so check that you've not mixed up one the injector multiplugs with the one from the iscv?
injector plug will be pulsing which would open & close the iscv quite fast causing your noise
Old Jul 27, 2007 | 11:07 AM
R5FORD's Avatar
R5FORD
nope mate there all in correc place.. must be the 2 wires as i havent changed none around
gingeRS
17
Oct 2, 2015 09:42 AM
timsrs
22
Sep 24, 2015 08:14 PM
Botts
Sep 22, 2015 02:04 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
rsturbo27
Sep 5, 2015 05:08 PM
