chargecooler rad 2wd saff?
Old Jul 26, 2007 | 01:45 PM
gibbo frst's Avatar
gibbo frst
Default chargecooler rad 2wd saff?
hi. i brought off ebay some time ago a pace turbocooler rad which i won for £15... it had no pic and i thought for that money it wont matter if its crap.. when it turned up its not like the normal turbo coolers as the outlets are in the wrong place.. looking through some pics i think that it is a radiator for a chargecooler as ive seen the same ones on a few track cossies... could this rad still be used as a turbo cooler before the header tank or should it be binned.... ? cheers..
Old Jul 26, 2007 | 02:28 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Pressure test it first, as they tend to leak. If it is okay, then if you can make it fit and plumb it in, then every little helps.
mark r
Sep 29, 2015 07:27 PM
cossie330
Sep 27, 2015 04:13 PM
DavidK
Sep 27, 2015 02:55 PM
ajamesc
Sep 27, 2015 02:25 PM
Russ Payne
Sep 25, 2015 08:29 PM
