refitting a dump valve, how? :cry:
need to refit my dump valve on my saff (as advised my NMS)
but cant remember how to plum it in
where does the little pipe from the top of the DV go?
PS can you use a pic to show me, cos even if you explain it i still wont understand
Originally Posted by Deal or No Deal Dan
Originally Posted by Cawood
goes into the what daboy?
dan i took it off ages go but been told to put it back on now
although to be honest chatter is getting pretty annoying now
it just needs to be engine side of throttle plate so that it sees vacuum on closed throttle to give a big enough pressure difference across the valve to overcome the spring and open the valve
if you have the original pipe, just route it properly and it should be obvious. presumably you have something fitted where it came from to blank it off, so that should give you your answer
sound cheers guys, think i'll be able to figure it out from that
n cheers foreigneRS
i've noticed there is a small hose on the right side of the engine, think its that i need to plum it into
just need a T-peice now
n cheers foreigneRS
Rab's Dump valve fitting guide
1. Thouroughly clean all areas of the dump valve with Carb cleaner.
2. Check, and ensure there is the correct amount of space in your household bin.
3. Open lid of said bin.
4. Deposit dump valve into bin, using a suitable degree of force.
5. Close bin lid.
6. Now is a good time to decide whether or not to remove bag and take outside for collection.
Congratulaions, your car no longer sounds like a bus....
5. Close bin lid.
Originally Posted by rs shawn
whosyadaddy
Can't even see it on that pic
Is it missing in that pic, but should be under the braided hosing just to the right of the airfilter (a small branch off the filter hose)?
turbochild
13
Oct 1, 2015 05:33 AM
