Wastegate `flutter`??
Old Jul 25, 2007 | 10:16 PM
cossie04's Avatar
cossie04
Default Wastegate `flutter`??
Might sound like a dumb question, but how to i get the `flutter` noise when changing gear instead of the usual dump valve going off?
Its on a T5
Cheers, Ed.
Old Jul 25, 2007 | 10:17 PM
mechanic28's Avatar
mechanic28
take off your dump valve fit a induction kit job done
Old Jul 25, 2007 | 10:18 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
lob the DV in the bin .then kiss your turbo goodbye
Old Jul 25, 2007 | 10:19 PM
Staffi's Avatar
Staffi
Just put your head out the window and go fliterrrrrrrr
Old Jul 25, 2007 | 10:21 PM
JTECH James
Passion for Fords!
or record my car onto a cd and play it really loud on your stereo
Old Jul 25, 2007 | 10:31 PM
cossie04's Avatar
cossie04
I take it don`t do the turbo any good then?
Old Jul 25, 2007 | 10:33 PM
mechanic28's Avatar
mechanic28
turbos can run ok without dump valves
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
My GT30 doesn't seem to mind. I have been running close to 2-bar of boost for ages now with no dump valve.
Old Jul 25, 2007 | 10:34 PM
rapidcossie's Avatar
rapidcossie
I would LOVE to know how you get WASTEGATE to flutter, chatter or make any noise for that matter?
Old Jul 25, 2007 | 10:36 PM
mechanic28's Avatar
mechanic28
u getting technical
Old Jul 25, 2007 | 10:37 PM
Christian and Beccy
#1 in Spelling Club
PMSL Euan, here we go again!!
There needs to be a sticky thread highlighting why it isn't the Wastegate that is making the noise!!!
OK, so it's the Compressor blades squirming in the backdraft that makes the noise, but I think it sounds worse than it is.
Old Jul 25, 2007 | 10:38 PM
rapidcossie
I have thought of a way....
Stick a pigeon in your air box and go for a run...
when it hits full boost it should be sucked in and.........................flutter
JTECH James
Passion for Fords!
i can get my waste gate to chatter euan
take all the pre load off the wastegate arm ,and the wastegate chatters around at idle
Old Jul 25, 2007 | 10:40 PM
rapidcossie
u getting technical
if the wastegate ever fluttered it would be fooked within minutes as would your turbo.
Im with Christian....we should get a sticky up then atlest we would be the only forum on the net with fully clued up members
How cool are we
Old Jul 25, 2007 | 10:41 PM
rapidcossie
You have achived the impossible...you should be on that heros programme
mechanic28's Avatar
mechanic28
u getting technical
How cool are we
ice fella
Old Jul 25, 2007 | 10:42 PM
Christian and Beccy
#1 in Spelling Club
Im constantly amazed at the amount of people that only own a turbo car for the 'Chatter' or 'Whoosh'.
rapidcossie
stick a k+n on it bruv
JTECH James
Passion for Fords!
the cheap shitter R5 gang
Old Jul 25, 2007 | 10:53 PM
cossie04's Avatar
cossie04
I bought my turbo car for its power and the fact i didn`t even pay a grand for it, not because it goes `Whoosh`.
Old Jul 25, 2007 | 10:56 PM
rapidcossie
why are you asking us how to make it woosh then?
Fit a super dooper wooshy valve and it will do it
joking aside mate you need to remove the airbox as this acts as a silencer.
Old Jul 25, 2007 | 10:58 PM
OvaBoost's Avatar
OvaBoost
And me...makes me laugh really - everyones like 'bruv your dumpvalves PHAT man!'
Old Jul 25, 2007 | 10:59 PM
cossie04's Avatar
cossie04
Thankyou, thats all i needed to know. If i`ve got the option to do it, then why not IMO.
Old Jul 26, 2007 | 04:33 AM
SS1's Avatar
SS1
does not the sound expel via the air filter. ive been asked and i would like to know myself
Old Jul 26, 2007 | 06:25 AM
Why not do as I do and have ALL THREE.
I can have whoosh, no noise or chatter, at the flick of two switches.
I have put on two dump valves one recirc, one atmo for loud/quiet but if both turned off you get chatter, less than Ł10 as well.
Old Jul 26, 2007 | 07:18 AM
Christian and Beccy
#1 in Spelling Club
V6 EDC - My remark wasn't directly specifically at you.
Avid-fan - Sorry, I don't understand what you mean. The air-filter is irrelevant, a car will 'chatter' with or without an air filter.
Old Jul 26, 2007 | 08:59 AM
SS1's Avatar
SS1
sorry will try to explain better.as my car has a recirc dump valve it has no loud whoosh noise
but very loud chatter.
i know its air backdraft through the turbo..but where is the sound actually emitting from
when it comes out of the car ??
Old Jul 26, 2007 | 09:03 AM
Christian and Beccy
#1 in Spelling Club
If you have 'chatter', then your dump valve isn't really doing its job properly. The trouble is, to get the valve to be effective at higher boost, it may be too strong and won't blow at lower boost levels, meaning that you will still get some 'chatter'. However, if it is set up soft, so that you get no 'chatter' it may leak in high rpm low load situations.
This is why we generally don't use them.
Also, the sound is emitted from the intake of the turbo.
Old Jul 26, 2007 | 09:11 AM
GARETH T's Avatar
GARETH T
thats not the best idea you have come up with! as the dump valves WILL leak if they have there signal hose turned off as the pressure differential accross the diaphragm will be high
Old Jul 26, 2007 | 09:13 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
I used to respect you so much
Old Jul 26, 2007 | 09:19 AM
So you are assuming I have not changed the springs etc and altered the vac lines via restrictors then ?
Old Jul 26, 2007 | 09:22 AM
RichardPON's Avatar
RichardPON
Is that really relevant?
You have a dump valve "on demand", which means you ONLY have it for "impressing" pedestrians.
SS1's Avatar
SS1
why bother asking
Old Jul 26, 2007 | 09:24 AM
Chip's Avatar
Chip
Indeed
Tabetha goes from PF Hero to PF Zero in a single thread.
Old Jul 26, 2007 | 10:29 AM
GARETH T's Avatar
GARETH T
i am assuming,,,
Old Jul 26, 2007 | 10:31 AM
Cawood's Avatar
Cawood
i need to refit my dump valve on my saff (as advised my NMS)
but cant remember how to plump it in
where does the little pipe from the top of the DV go?
Old Jul 26, 2007 | 10:37 AM
boXXer's Avatar
boXXer
GASH!
into the inlet manifold i think.
What turbo you running then?
Old Jul 26, 2007 | 10:55 AM
Redkop's Avatar
Redkop
A detailed explanation of compressor stall/chatter HERE
Old Jul 26, 2007 | 07:15 PM
Red16's Avatar
Red16
u getting technical
How cool are we
the MLR has a monthly magazine for members called Wastegate Chatter
