cosworth gearbox what have you got fitted 2wd
ok what option do i have with a 2wd t5 gearbox what are people using and whats it cost you and were ... need some option as i have broke 2 boxes now and its not fun
I have been trying to break the box in my car for the last 5 years and it still dont break
Been trying to break it so i would have an excuse to get an uprated one as the baulk rings need doing on mine.
Originally Posted by Ryan
ran you t5 is fookin shocking
quite a few options available now.
As said, anything can be made to fit, just depends on your budget.
T56
Tremec TKO
Getrag
Quiafe
T56
Tremec TKO
Getrag
Quiafe
Have used the Tremec TKO for 8 years with no probs. Has been abused at close to 900bhp & will be asked to take more soon . Be assured you wont break it. Zoo did do the conversion but not sure of Broms situation at the mo & the box is cheap.
Originally Posted by abdr500
any idea why my gearbox starts to wine first i have never broke a gear wqhats the price range on the above boxes
Out of interest what kind of price is cheap for the box rod?
RS Specialists
i dont no if i want the box to be very loud how much
I RUN GETRAG JAG BOXES IN MY RS500s ,BOTH CLOSE ON 600BHP ,THESE ARE SYNCRO BOXES SO GOOD FOR THE ROAD 2.NEVER HAD A PROBLEM AND I GIVE THEM ABUSE !
THEY HAVE THE SAME CLUTCH SPLINES AS COSWORTH AND MATE UP TO THE FORD BELL VERY EASILY ETC
Mine came from an XJS.
easy to identify as its the only one box that comes with a detachable bell housing.
Its called a 265.
Thru the gears its closer than a T5 but the 5th is slighty longer.
Its called a 265.
Thanks Euan
What did you have to do to fit it ? ie clutch spline, input shaft diameter into spiggot bearing, input shaft length (spacer plate between box and bellhousing), prop UJ, gearlever position ?
Originally Posted by jon@work
Thanks Euan
You will need to mod fron of prop and gear linkage a bit.
I dont do the work myself but the adaptor plate is a spacer too
so to bolt it to the engine, it's as easy as making up an adaptor plate between the box and the bellhousing ? Sounds unusually straightforward. Don't suppose you know the exact thickness of your adaptor plate, do you, or could let me know when you're next under your car ?
Originally Posted by escort700bhp
from any xj40 or xjs jag 1986 to 94
i have plenty for sale ,i also have some spare adaptor plates
I mean that the prop wont line up right...even if its off my millimeters it wil shake the car to bits.
I will measure it but will be a week atleast before i see car again.
as i have explained in a pm no standard t5 will last at the power your running they will last for so long then they will let go
like i said i could get one full overhauled with brand new sycro's bearings seals but there wont be no piont id be taking the money off you knowing that they wouldn't last
why dont you just buy a TKO 600 and get someone to fit it end of story then that will last
marco
i'm sure i could lay my hands on a box but what other parts would i need?
