different maps on a chip
Old Jul 24, 2007 | 08:34 PM
Maxiboy's Avatar
Maxiboy
Default different maps on a chip
can you get different maps on a chip and switch between them or get multipull chip carries and switch between chips from in the car. or other solutions....
want to be able to switch between my 250bhp/350bhp maps at a touch of a button.
Old Jul 24, 2007 | 08:36 PM
gus's Avatar
gus
depends on what ecu your on i guess
2 stage boost?
JTECH James's Avatar
JTECH James
Passion for Fords!
why would you want to?
Old Jul 24, 2007 | 08:38 PM
JTECH James
Passion for Fords!
i take it you want economy, on one and power on another,
i would just run the 350 spec all the time ,and have closed loop
Old Jul 24, 2007 | 08:43 PM
Maxiboy's Avatar
Maxiboy
cheers. closed loop will help economy then.
Old Jul 24, 2007 | 08:44 PM
Stu @ M Developments's Avatar
PassionFords Creator
We do these for many different OEM ecu's.
A couple of good reasons do map switches are:
1) Race fuel and normal fuel.
2) A few customers have taken them with lower boost maps and rev limiters in one map for their girlfriends safe use.
3) A Valet map that will only allow a person to move teh car around for servicing etc. Say with a 3krpm rev limiter.
We normally supply these map switch system on a key switch for added security. Select girlfriend or valeter map and remove key. Job done.
Old Jul 24, 2007 | 08:47 PM
JTECH James
Passion for Fords!
SWEET Stu! when you flick the girlfreind switch it would be even better if the bumpers grew an extra foot aswell and disables reverse gear so she cant try and park the thing!
Old Jul 24, 2007 | 08:49 PM
Miller 3's Avatar
Miller 3
Something else to add to the list
Old Jul 24, 2007 | 09:09 PM
Maxiboy's Avatar
Maxiboy
is this on a different chip carrier basis or just an electronic switch.
Old Jul 24, 2007 | 09:10 PM
markk's Avatar
markk
i had one of these in my last car from MSD - works very well can be switched on the move as well.
Old Jul 24, 2007 | 09:17 PM
Varies from system to system, help us out here, is it a Porsche 911? Skyline R32? Fiesta 1.1 Unpopular? Escort Turbo? Mercedes SLK?
Old Jul 24, 2007 | 09:26 PM
Maxiboy's Avatar
Maxiboy
sorry mate its a clio maxi turbo running a fast chip 250bhp map but i,ve a 350bhp and its going for a custom mapping once run in to see what it will do.
but i like the 250 for every day but being able to up once moving if i want too.
cheers stu. much appreciated maxiboy
Old Jul 24, 2007 | 09:31 PM
What management are you using on her?
Old Jul 24, 2007 | 09:40 PM
Maxiboy's Avatar
Maxiboy
standard ecu with a fast chip in a carrier. am i better upgrading
Old Jul 24, 2007 | 10:02 PM
No, we can probably hook up a swop board for that. The problem is, i would need to know what sort of prom your tuner used and weather or not its encrypted, as if it is, its a no go.
Old Jul 24, 2007 | 10:19 PM
Maxiboy's Avatar
Maxiboy
yes mate there an encrypted chip on the eprom. think i,ll have a look into a swap board. cheers for all your help.
do you do stand alone system that can swap maps then.
and a rough price please
Old Jul 25, 2007 | 07:39 AM
foreigneRS's Avatar
foreigneRS
Testing the future
many aftermarket ecu's do this if that's the route you want to go down
girlfriend's safe use? that's a bit sexist and patronising isn't it stu?
if you want to keep your car safe from your girlfriend, don't give her the keys
Old Jul 25, 2007 | 08:13 AM
gingeRS's Avatar
gingeRS
cant you just control your right foot?
hardly seems worth it swapping between 250-350bhp on a clio.
the stuff about the girlfriend/valet mode seems very clever stu
Old Jul 25, 2007 | 08:42 AM
Jay,'s Avatar
Jay,
Sponsor
ive just aquired this from emerald !just a a few more bits and bobs to do then it will be on my cossie if you cant get it from stu on your system this will do triple map
http://www.emeraldm3d.com/em_k3.html
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
