Do BD10's have a ford logo on?
Old Jul 24, 2007 | 07:41 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
Default Do BD10's have a ford logo on?
My mates looked through the oil cap on my new engine and spotted a ford logo...he reckons it cannot be the BD10 It was sold as......
Any Ideas? As I have photos of cylinder head (deffo this one can tell by certain marks on the head and in the pics) with a full port/polish, kent foolowers and kent bd10 cams....all done by cylinder head developments.....got the receipt for 1500 here in my hand....
Any info Appreciated
Dan
Old Jul 24, 2007 | 07:43 PM
jon@work's Avatar
jon@work
will have logo if reground to BD10 spec as opposed to being made from a blank
Old Jul 24, 2007 | 08:19 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
Normally when u buy bd-10`s you buy them on exhange basis, so that they can re-grind the std to bd-10 spec, so therefore the ford-logo.
You can always check them on the back end, there has to be stamped BD-10 on them.
If blank then they are std
Old Jul 24, 2007 | 08:32 PM
SillyFezzaMk1
Rubber Rhino Crew
cheers, I have to have the rocker cover off soon to have it freshened up so will look then, im 100% sure that cylinder head developments have put a bd10 in there its more to do with proving my cocky arsed know it all mate wrong
Dan
Old Jul 24, 2007 | 08:48 PM
cossiemanden
Hehe, god luck with it
Old Jul 24, 2007 | 09:44 PM
CosKev3's Avatar
CosKev3
As above,check the rear end of cam facing the bulk head
If Kent Cams should have KC BD10 stamped on it
Have a small mirror ready so you can slide it down between the back of head an bulkhead to read info on rear end of cam
Old Jul 25, 2007 | 11:34 AM
SillyFezzaMk1
Rubber Rhino Crew
sweet! I have a little weld inspecton mirror just for the job
Dan
Billy_RS
16
Oct 11, 2025 09:41 PM
Danielbetty
Oct 3, 2015 06:01 PM
borboyous
Aug 22, 2015 11:17 AM
