problem with clutch on 4wd cossie
rite
i went to see if the car moves today for the first time since build
it has a new alcon clutch and new ford cable
when i press the clutch fully i get a grinding noise
i can still get it into gear and if i go 3/4 way downand not fully but something isnt rite
ive spoken to martin @ reyland and he said that it could be travelling too far and that the clucth forks are being pushed into the plate which sounds logical
so has anyone had this before and is there a temp fix for it unless i can manage to get the money together in time to go hydraulic which i should of done in the first place
the ratchet system works fine on the pedal aswell
any ideas
any ideas
I had simlar on mine but it ended up been the cover that was fooked, ended up taking box off 3 times to find that out, and changed ratachet, cable, spigot, and the box as i was reliably informed that the cover had only done 300 miles since fitting,
It is over tensioned just release the tension, lift pedal up with one hand and PUSH against the ratchet part with the other hand/thumb all the way it will then start the tension over again, sounds like someone has inadvertently pressed the pedal with out box/clutch attached.
Originally Posted by lloyd
would a standard clutch cable help,the ones that have 2 17mm nuts to adjust the length at the bell housing?
didnt know there was variations though
i just carnt understand why its pulling the release bearing so far in as everything is on correct
yes new 4wd release bearing
yes as i had to change the arm before i fitted it as the arm was just falling off so replaced one that made sure doent come off
properly has me confused and i dont want to drive the car incase i really mess it up
the relase bearing is fine im 100%
as i can select gears fine etc if i put the clutch 3/4s down
but if i was to fully depress the clutch as you would do normally driving (well i do anyhow) then there would be a grinding noise coming from the clucth
kosienutter
31
Aug 22, 2015 09:55 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
lockie
Jul 31, 2015 10:03 PM
