Sierra Dash
You want one from any 1988 on hatchback Sierra rather than a saff as the corners where the windscreen pillars come down are different on the saff version, otherwise the pillar covers dont quite fit right
3 door dash is different to the 88-90 spec dash
which is different to the 90-91 dash
which is different to the 92 spec dash
pre 90 spec and post 90 spec are fairly different but you can swap them over
you will need to have everything, and i mean everything from the 90 spec car to transfer over, inculding heater controls, switches (which will be a problem as the looms are different) indicators (and wires and stuff) as well as the ecu brackets, the kick panels, even the centre consoles bolt up in a different place
you will also need to be a be "creative" when it comes to placing the aws stuff as well, but it's not difficult, just time consuming getting everything to line up properly
Well........Thats told me......Great Info guys...So does ANYONE have a 3 door dash ..Thats not SPLIT.. to sell me..R/H drive for now...........Very tired now...Time for bed..
chowfornow
14
Jan 5, 2019 09:01 PM
SMILER258
Sep 28, 2015 09:04 AM
