Where to find a 3 outlet Master Cylinder for RS?
Old Jul 17, 2007 | 01:54 PM
seand's Avatar
seand
Default Where to find a 3 outlet Master Cylinder for RS?
Hi All
The problem i have is the seals in the master cylinder have packed in which leaves me with no breaks only the handbrake. the problem is that this cylinder in not a standard RS cylinder. The standard cylinder has 2 outlets, one of these outlets is split between each of the front wheels and the other outlet goes to the back. On the master cylinder that is on my car there are three outlets. As you look at it on the car the two outlets on the left are used for the front brakes one outlet per corner, this gives max stopping power. the other outlet has a bias regulator on it and and controls the back brakes. The problem is i dont know where to get one of these 3 outlet master clyinders? Or what car they are off? or if it was an after market upgrade. The RS has cossie brakes fitted if this helps.
Any help greatly appricated.
CheeRS
Gerard
Old Jul 17, 2007 | 04:11 PM
bad boy rs's Avatar
bad boy rs
recently changed it on my rs aswell and my mate at bennets had both types in stock so find your nearest bennetts mate
TPM961
Jan 15, 2018 10:50 AM
155lee
Oct 27, 2015 04:55 AM
Flateric_2002
Sep 15, 2015 08:41 AM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
