valve spring compressor for YB head
Old Jul 17, 2007 | 08:09 AM
foreigneRS's Avatar
foreigneRS
Testing the future
Default valve spring compressor for YB head
i need to buy a valve spring compressor today that is suitable for the YB head. can anyone recommend one please? will a sykes pickavant one do it? do halfords have one?
thanks
Old Jul 17, 2007 | 08:12 AM
Altratz's Avatar
Altratz
If your trying to remove them just use a 24mm socket with a short extention and hit the end with a lump hammer very quick simple and effective just make sure you do it in a well lit area as not to loose the collets!
stripped my complete head down the other day in just over an hour works starts on the bottom end today!
Old Jul 17, 2007 | 08:34 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i'd like to refit them as well
Old Jul 17, 2007 | 08:36 AM
Altratz's Avatar
Altratz
Lol speed demon not sure turbo can come off in that time?
im just gonna get the local machine shop to build them back up about Ł30 means if there is any cock ups its there responsibility!
regards Alex
Old Jul 17, 2007 | 11:23 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Default Re: valve spring compressor for YB head
thanks
I have the Large halfords sykes pickavant one, it works perfectly , just remember to over centre it, as it is far easier to use , not swear at it and use a 4ft extension bar over it like I did first time
Old Jul 17, 2007 | 11:53 AM
foreigneRS's Avatar
foreigneRS
Testing the future
RWD_cossie_wil thanks for that will see if any of the local ones have one in stock
Old Jul 17, 2007 | 12:07 PM
I welded a old cut about socket onto my old spring compressor to allow it to go deep enough.
Old Jul 17, 2007 | 12:27 PM
foreigneRS's Avatar
foreigneRS
Testing the future
tabetha i used to use a piece of tubing welded to a clamp with a slot cut out of it
Old Jul 17, 2007 | 02:07 PM
foreigneRS's Avatar
foreigneRS
Testing the future
RWD_cossie_wil is it like either of these? i guess the first, as i can't see how the second would work
http://www.halfords.com/webapp/wcs/s...tegoryId=71557
Old Jul 17, 2007 | 02:53 PM
RWD_cossie_wil
top one mate, the bottom one is for the ones that have a protruding top edge, like CVH followers I think
Old Jul 17, 2007 | 03:00 PM
foreigneRS's Avatar
foreigneRS
Testing the future
RWD_cossie_wil thanks a lot mate
from the tool that i have made up in the past, that one looks like it should work
Old Jul 17, 2007 | 03:01 PM
RWD_cossie_wil
It will work 100% mate, it's what I have used on many YB's and loads of other engines Also, a set of these : http://cgi.ebay.co.uk/DRAPER-280mm-L...QQcmdZViewItem
makes the job of picking the collets out 1000 times easier
Old Jul 17, 2007 | 05:31 PM
the original's Avatar
the original
get some pictures of the bent valves if you can
Old Jul 17, 2007 | 08:51 PM
foreigneRS's Avatar
foreigneRS
Testing the future
bought the top one from bracknell halfords. hopefully my mate will be able to work it.
Old Jul 17, 2007 | 10:57 PM
Fiecos Dan's Avatar
Fiecos Dan
i used a Drapers universal deep throat item.
But as mentioned the collets need the seal breaking.
On sunday i striped and rebuilt my cossie head, i found using the standard 'hammer and socket trick' over the spring cap didn't work, no matter how hard i hit it.
So i had to use 2 Sockets with a Calver clamp to break the collet away from the spring cap.
kevin36
Sep 9, 2015 11:12 AM
kevin36
Sep 8, 2015 12:23 PM
Adam Graham
Sep 6, 2015 06:04 AM
cossirob
Sep 3, 2015 09:17 PM
