Ign timing on a S2 EFI conversion
Old Jul 16, 2007 | 10:30 PM
o n i o n's Avatar
o n i o n
Default Ign timing on a S2 EFI conversion
Hi folks.
Just finished doing an efi conversion on a friends S1 using an ofab ecu.
The guy who owns the car came to see me for a bit of advice, cause he wanted to do as much work as poss himself.
He wanted to install the CKP himself. This is where I made a fundamental fook up
Never told him to drill it at the right position in relation to tdc.
I wired it up and got it running after a few teething probs and horribly corroded earth wires.
To cut a long story long, I am worried the ign timing might be well out.
Is it possible, when mapping, they can find where the base/ static timing is at and use this as the control to advance or retard the ign to get the correct setting.
So for example if it is idling, with vacuum advance off at only 6deg, could a tuner put an extra six on and obviosly a factor of 6 up the whole map.
And if this was possible, what would happen if there was a problem and it fell in to LOS mode, or does mapping erase this function anyway.
Sorry if this is 100% bollocks what I have written, but I don't really understand it yet, and sorry for going on too,
Story over, cheers.
Old Jul 17, 2007 | 08:34 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
If I have understood correctly and depending on the management used, you can read the timing off the front pulley with a strobe, then tie that up with the management.
Old Jul 17, 2007 | 04:30 PM
o n i o n's Avatar
o n i o n
Right, so no need to panic just yet!
Will check it with a strobe on the weekend to see how far we're out.
I guess it will then be a case to see if it is possible to alter the settings using fiesta turbo management.,
What a dick head I am
Old Jul 17, 2007 | 04:41 PM
xr4x4rs's Avatar
xr4x4rs
do you mean the cps?
Old Jul 17, 2007 | 04:45 PM
o n i o n's Avatar
o n i o n
Yes, sorry.
Old Jul 17, 2007 | 04:49 PM
xr4x4rs's Avatar
xr4x4rs
if its been drillled into the block where it would normally go on a efi car to face inside the flywheel
as long as your using a efi flywheel and its sort of central to the pick uppoints you will be fine
as the flywheel will only go on one way round
Old Jul 17, 2007 | 04:54 PM
o n i o n's Avatar
o n i o n
Yeah, I think that's where I might have a problem.
Never timed up the true postion in relation to top dead centre.
Car runs ok, just not sure untill I get hold of a strobe, where the ign timing is at.
Are we buggerd if it is too far advanced or retarded?
Old Jul 17, 2007 | 05:02 PM
xr4x4rs's Avatar
xr4x4rs
i wouldnt of thought it woud of matter but no thinking about it i can see your point
i was under the impression that as long as it see a 32-1 i think then it will be fine
but now as you say if its in the wrong postion it could be out
sorry carnt be anymore help than that im afraid
as its got me confused now
Old Jul 17, 2007 | 05:06 PM
o n i o n's Avatar
o n i o n
Cheers bud.
Got me in a right state too.
But you get where i'm coming from, which means I'm not going mad.
Old Jul 21, 2007 | 06:08 PM
sexr3i's Avatar
sexr3i
isn't it
you'll have to pay like 500 quid to get that mapped though as theres virtually nobody who can map it so they charge what they want. Would be cheaper to get a FRST block
EoinXR3
Sep 7, 2015 05:44 AM
s1turboman
Aug 29, 2015 04:27 PM
Red_bull
Aug 25, 2015 06:27 PM
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 17, 2015 12:21 PM
