Turbo feed pipe leaks 2wd sapphy
Old Jul 16, 2007 | 07:30 PM
Default Turbo feed pipe leaks 2wd sapphy
Where the metal pipe goes into the "ring", through which the BANJO bolt passes is leaking, on the coolant feed pipe, I have tonight seen one other that has come out completely on a 4wd, how common are problems here has anyone else had this ?
I am thinking of using flexi pipe when I find some suitable or some other means as this is just silly.
Thanks .
Old Jul 16, 2007 | 07:33 PM
Jasesapphy's Avatar
Jasesapphy
i had this bought a new pipe from woodford in the end for £20 quid, but had exact same problem
Old Jul 16, 2007 | 08:00 PM
What did you do in the end, I am thinking of TIGGING it.
Old Jul 16, 2007 | 08:08 PM
Fiecos Dan's Avatar
Fiecos Dan
you can get it brazed repaired,
or above, just buy a new/used item.
i guess your's has split the brazeing?
Old Jul 16, 2007 | 09:39 PM
Jasesapphy's Avatar
Jasesapphy
brazing goes, i just bought a new one for the £20 they cost
Old Jul 16, 2007 | 09:41 PM
R4N SS's Avatar
R4N SS
i hzd this and bought a new one - problem solved.
Old Jul 16, 2007 | 09:44 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
who sells new ones
Jasesapphy's Avatar
Jasesapphy
woodford
Old Jul 16, 2007 | 09:46 PM
RS500/364's Avatar
RS500/364
Been there done it got three spare just incase
And so have my mate well two off them
Old Jul 16, 2007 | 10:16 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
just fit aeroquip banjo fittings.
Old Jul 17, 2007 | 04:57 AM
Decided to flexy pipe it, even if it means machining fittings up myself, as I worry about things like this, doing return as well, just to be safe.
Thanks for the input all,
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
muz
Aug 16, 2015 12:57 PM
