Renault Megane Coupe what to look for?
Mrs is looking at a megane coupe
what should we be looking out for anything in particular to watch out for?
In particular the 1.6 16v engine any good?
Your help and advice will be gratefully received thanks
What to look for? A different car.
French car= Wank, in huge amounts. The only thing wanker than french cars is working on french cars. If you buy one you need your head looking at, Never has a pile of brittle plastic and horrid thin kitkat wrapper thick metal ever been put to a worse use, and the electrics look good......if you like a burnt charred mess on the floor of your car and random flashing lights
Wank.
Wank.
Yeh the coil packs always go its better 2 change the coils in pairs cause if u replace cylinder 1 coil ur can b sure that no 4 will go 2. Like said above renaults r a awful car 2 work on.
borboyous
Aug 22, 2015 11:17 AM
Clare
Aug 18, 2004 10:03 PM
