1600i ARB clamps
How the hell do these come off?
It looks like once you take the 8mm nut off the bolt, the bolt should slide out and then the whole thing ahould open up (Hinge at the opposite end to the bolt?). Is that right?
Thanks for any advice
I was right. But the alloy in the bolt holes was corroded so the bolts wouldnt come out. Got them out eventually though...
Anyone know if you can get the poly bushes that go inside the clamps?
truffleshuffle
Sep 10, 2015 09:35 PM
chris m1
Sep 7, 2015 08:02 PM
