corroded water ways in head and pistons?
Old Jul 15, 2007 | 09:04 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default corroded water ways in head and pistons?
couple of question my head has some corroded water ways
like this will this be a problem this wernt the cause of gasket failure btw
and are these std pistons for 4x4?
Old Jul 15, 2007 | 09:17 PM
rapidcossie's Avatar
rapidcossie
head is fucked and yeah they are standard.
Dicko&Vacant's Avatar
Dicko&Vacant
i thought my headgasket had gone untill i removed the head to find that the head was severely corroded like yours
so that is more than likely your problem
Old Jul 15, 2007 | 09:23 PM
Roosie's Avatar
Roosie
cars only done 80k
another expensive job
Old Jul 15, 2007 | 09:32 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
isn't it caused by not using anti-freeze...?????
Old Jul 15, 2007 | 09:34 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
looks like a fair bit of valve contact on the pistons also.
Steve
Old Jul 15, 2007 | 09:37 PM
Miller 3's Avatar
Miller 3
Or to much
Old Jul 15, 2007 | 09:41 PM
abdr500's Avatar
abdr500
buy the looks of it thers still a nice chunk left for the firing ring to seal on but for the sake of getting it alloy welded and skimed will only cost you some thing like Ł80 my head was like this
Old Jul 15, 2007 | 09:51 PM
Roosie's Avatar
Roosie
if it can be done i will get that done
i dont know why the valves have touched the pistons slightly as its never been skimmed head etc
Old Jul 15, 2007 | 09:52 PM
Roosie's Avatar
Roosie
always used ant freeze but dont knpw about other owner
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
the valves touch the pistons when it does a few too many revs
Old Jul 15, 2007 | 09:56 PM
Roosie's Avatar
Roosie
must of been previous owners i never rev it hard
Old Jul 15, 2007 | 10:04 PM
Billabong's Avatar
Billabong
A missed/fluffed gearchange will do the trick too.......
Old Jul 15, 2007 | 10:07 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Hmm, not good Roosie.
By the way - I've now found that Oil seperator breather thingy ma jig if ya still need it. Was buried in my shed.
Si
Old Jul 15, 2007 | 10:08 PM
The Youth.'s Avatar
The Youth.
the head on my saph was like this, I got it welded at an engine specialist and the car is still going strong now some 7 years later!!
steve
Old Jul 15, 2007 | 10:09 PM
Roosie's Avatar
Roosie
cant remember what it looks like now have u got hoses with it? and is it 3 port ?
Old Jul 16, 2007 | 06:23 AM
As said no antifreeze causes it, water loves to corrode!!
3i Jim
Nov 20, 2015 05:12 AM
KW-rscos
11
Aug 31, 2015 01:51 PM
YODI
Aug 30, 2015 01:12 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
ekjim
Aug 17, 2015 08:57 PM
