New AP's 362x32 fitted. when do they perform?
Old Jul 14, 2007 | 10:01 PM
leecavturbo's Avatar
leecavturbo
Default New AP's 362x32 fitted. when do they perform?
bedding them in at the mo, so just light braking.
but i expected to have that enormous stopping power
feeling with even the lightest of pedal push?
or will they just come good when bed in?
Old Jul 14, 2007 | 10:04 PM
Mark Shead's Avatar
Mark Shead
You say AP but your pict says Brembo .
Mark
Old Jul 14, 2007 | 10:06 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Mark
pmsl
Old Jul 14, 2007 | 10:07 PM
leecavturbo
Mark
ok the disc's
Old Jul 14, 2007 | 10:10 PM
Mark Shead's Avatar
Mark Shead
Mark
ok the disc's
Are you sure as the grooves on the discs arent from any AP I have seen,
Normaly I recommend 200miles carefull driving before testing them but this also depends on the pads on how they are meant to be beaded in.
Mark
JonnyBravo's Avatar
JonnyBravo
I would of thought the pads were the main thing causing a crap feel on the pedal.
Aren't they a bit of a overkill on a 300hp chavalier
Old Jul 14, 2007 | 10:18 PM
leecavturbo
300! i'm surprised you can see what your typing
with your head in a bucket of sand
Old Jul 14, 2007 | 10:19 PM
leecavturbo
Mark
ok the disc's
Mark
there 110% AP
Old Jul 14, 2007 | 10:22 PM
rapidcossie's Avatar
rapidcossie
Ap dont make discs
Old Jul 14, 2007 | 10:26 PM
leecavturbo
Ap dont make discs
well gen me up then? cus these came in ap boxes sealed and have ap part no@s on?
Old Jul 14, 2007 | 10:27 PM
Dicko&Vacant's Avatar
Dicko&Vacant
well this is gonna be an interesting thread
what are the calipers off?
JonnyBravo's Avatar
JonnyBravo
I see you just changed your siggy
Old Jul 14, 2007 | 10:28 PM
JonnyBravo's Avatar
JonnyBravo
Ap dont make discs
If AP dont make discs then why is it that they are the only people to supply them for the Lotus Carlton
Old Jul 14, 2007 | 10:32 PM
leecavturbo
gen ?
Old Jul 14, 2007 | 10:34 PM
JonnyBravo's Avatar
JonnyBravo
I have a dozen of those boxes mate so I am quite sure AP DO make discs.
As AP do brake kits I'd be suprised if they use someone elses discs in their package
Old Jul 14, 2007 | 10:37 PM
dave cos4x4's Avatar
dave cos4x4
i thought AP only had about 8 grooves on them.
why have they changed them,or made different types.
Old Jul 14, 2007 | 10:40 PM
JonnyBravo's Avatar
JonnyBravo
@ your sig
There is no H in Jonny either
Old Jul 14, 2007 | 10:44 PM
rapidcossie
I spoke to AP about getting discs for mine and they said they only make the calipers and then put me in touch with a company called BG developments who make the kits up for each car.
Old Jul 14, 2007 | 10:45 PM
JonnyBravo's Avatar
JonnyBravo
Mike Rainbird has supplied my mate with AP discs for his 3 door several times.
Old Jul 14, 2007 | 10:46 PM
leecavturbo
thats for brackets etc i would imagine. but AP manufacture discs and calipers ????
Old Jul 14, 2007 | 10:52 PM
JonnyBravo's Avatar
JonnyBravo
http://www.apracing.com/car/brakedisc/index.htm
Old Jul 14, 2007 | 10:57 PM
rapidcossie
I could be wrong
Old Jul 14, 2007 | 10:58 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
you forgot the 's for euan
Old Jul 14, 2007 | 11:01 PM
rapidcossie
Ill take them on the chin chop
Old Jul 14, 2007 | 11:02 PM
JonnyBravo's Avatar
JonnyBravo
Old Jul 14, 2007 | 11:25 PM
NEIL A's Avatar
NEIL A
They are ap disks but the calipers are Brembos ment for a Jaguar as it the same kit as ive just got from Reyland.
Old Jul 15, 2007 | 08:55 AM
Chris Honeywell's Avatar
Chris Honeywell
I found that when i went from 4pot 330mm APs
to 6 pot 355mm APs they did have less bite and feel softer in use
but they worked well when hit hard
Old Jul 15, 2007 | 10:23 AM
Crowder's Avatar
Crowder
what pads are you running? also is the master cylinder man enough only ask because i know little about vauxhalls!
Old Jul 15, 2007 | 10:57 AM
leecavturbo
ds2500 iirc the number!
master cylinder i have no idea! maybe marco could gen us up?
Old Jul 15, 2007 | 11:12 AM
JonnyBravo's Avatar
JonnyBravo
I had no problem with my Ferodo 2500's
Are you using the OE Master Cylinder ?
Old Jul 15, 2007 | 11:29 AM
leecavturbo
yeah y, summat i need to know?
Old Jul 15, 2007 | 11:34 AM
Phil's Avatar
Phil
Jeebus
leecavturbo
If you want to get ultra sharp braking just touching the pedal then you need to fit a bigger master cylinder. This will push more fluid pressure down the brake lines for a smaller movement of the pedal.
Fitting bigger brake calipers often reduces the sharpness of the pedal as they have a bigger piston area and therefore takes more fluid pressure to push the pistons into the pads etc. Therefore fitting a bigger master cylinder will compensate for this.
But for a track car it is good to have a weaker setup to allow for more modulation on the brake pedal (depending on driver preference)
Also pads can affect it of course, but you have DS2500's and they are good!
Old Jul 15, 2007 | 11:42 AM
JonnyBravo's Avatar
JonnyBravo
As above mate, its important to get the right MC if possible.
I left mine alone on the nova but have have recently tried a astra 16v cylinder to improve the feel of the pedal.
Not sure how well its worked yet as the car hasn't been used
Old Jul 15, 2007 | 11:53 AM
Eagle's Avatar
Eagle
Super Moderator
my ap 6 pot 330's on ferrodo 3000 pads made the back end all floaty on serious stopping time to wind up the front suspension after that
Old Jul 15, 2007 | 11:54 AM
Noisy Boy's Avatar
Noisy Boy
well i thought then kind of discs have to be hot to really work good?
wowk
Mar 30, 2021 07:49 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
