Cosworth and pinto Big ends and main's, are they the same?
Old Jul 14, 2007 | 07:44 PM
Fiecos Dan's Avatar
Fiecos Dan
Default Cosworth and pinto Big ends and main's, are they the same?
as title really,
Had my cossie crank ground, and the Firm also got me some H/D lead/copper shells.
But on the box it says Pinto, They are the correct size and design, but not sure if they will be ok?
Mains, = -0.5mm, AE M91350,
Big's = -0.25mm, AE B91349.
Old Jul 14, 2007 | 07:58 PM
I always thought the cossie ones were a better material.
It might be that AE use the cossie spec ones for all instead of making two different specs that's all.
Old Jul 14, 2007 | 08:00 PM
Fiecos Dan's Avatar
Fiecos Dan
Thats what i thought.
tried doing a search for AE part numbers, but no luck,
i would ask my machine'st, but i recieved the crank and shells 17.30 last night, and by which time he had gone home for the weekend.
Old Jul 14, 2007 | 08:01 PM
david's Avatar
david
Got AE ones before for mates engine, orderded and supplied correctly for a cosworth but marked up as pinto. Never had any problems with them the time they were in.
Must be just as Tabetha says.
Old Jul 14, 2007 | 08:03 PM
Fiecos Dan's Avatar
Fiecos Dan
My mate has had quite a few cossie cranks done there, and always get the same shells,
but all his customer engines are std - 300 bhp, with out issue.
but mines used alot harder, and at least 450 bhp /lbft.
Old Jul 14, 2007 | 08:06 PM
JonnyBravo's Avatar
JonnyBravo
There is a difference as my engine builder mentioned it to me the other night.
I can't remember exactly what it is but if your building a high power engine then I imagine its quite important you know the correct info
Edit:
Its not the width of the bearing is it ?
Old Jul 14, 2007 | 08:11 PM
Fiecos Dan's Avatar
Fiecos Dan
The actual size of the new items are the same as my Ford cossie items that were in the engine before.
Old Jul 14, 2007 | 08:17 PM
JonnyBravo's Avatar
JonnyBravo
That possibly rules that out although can you be sure they were genuine cosworth ones you had in it before ?
Not being picky, I just remember something that was said about the bearings, I could be getting it mixed up with the big ends.
Been told a few things recently which are probably the cause of failure to some apparently well built engines, mine being one of them.
I'll see if I can get hold of him tomorrow to see what it was he mentioned
Old Jul 14, 2007 | 08:33 PM
Fiecos Dan's Avatar
Fiecos Dan
i'll check the ford part number, then we're know if they are.
i checked both the mains and the big ends against the ones that were in my engine.
Old Jul 14, 2007 | 09:10 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Are the main bearings grooved on one side and plain the other as in the cosworth bearings.
Steve.
Old Jul 14, 2007 | 10:34 PM
marco polo's Avatar
marco polo
i think normal pinto shells are zing and tin
cossies are lead /copper
Old Jul 14, 2007 | 10:40 PM
Fiecos Dan's Avatar
Fiecos Dan
Marco,
i believe thats true, and these are lead/copper, but wanted to make sure they are up for the job.
Steve.
just checked them,
Ford main's are as you quoted, but the AE 's are both grooved, but i'm not bothered about that, as the main's should be fine.
its the Big ends which has the most stress, and they are identical on apperence.
My ford shells
mains, Ford V3A V86HF 6333,
Big ends, Ford F8 220172 V86HF 6211
Old Jul 14, 2007 | 11:15 PM
daz1968's Avatar
daz1968
when I did my engine last year, I was told that cosworth mains are one grooved and one plain, whereas pinto ones are both grooved, I presume more surface area = better support of the crank, if you going for big power don't skimp on the cheaper items, I believe you can buy the plain ones individually from cosworth or ford and use half the mains set you have and end up with it correct, I believe the big ends will be fine though.
Old Jul 15, 2007 | 12:16 AM
Karl's Avatar
Karl
Norris Motorsport
I would have helped, but I am in breach of trader rules.
Old Jul 15, 2007 | 07:58 AM
fordpop's Avatar
fordpop
if you use both grooved mains bearings you will have no oil starvation to bigends at high revs
cosworth bearings are harder
Old Jul 15, 2007 | 08:03 AM
Jim Green's Avatar
Jim Green
If you contact NMS....they'll give you the correct answer.
But don't call Karl.........
When I rebuilt my engine I ordered "Cosworth Bearings" from Woodford Garage, and the word "Cosworth" was on the packaging.
Old Jul 15, 2007 | 08:21 AM
Moonstone Steve.
the ones i got from Burtons where wrapped in brown paper
Steve.
Old Jul 15, 2007 | 08:45 AM
yrkesman's Avatar
yrkesman
I doubt that these big power cossies stay in one piece that long that the bearings would fail, even if they are the standard pinto ones. As long as everything else is okay (oil, oil pressure, etc). But I'm no expert so I could be wrong.
Old Jul 15, 2007 | 08:58 AM
Fiecos Dan's Avatar
Fiecos Dan
i won't complain.
You will have oil starvation, or wont??
i could only see this possible if the crank and shells are worn, as the tolerance is what causes the pressure, not the groove.
This are meant to be lead/copper heavy duty items.
Old Jul 15, 2007 | 05:19 PM
Fiecos Dan's Avatar
Fiecos Dan
anyone else please?
Old Jul 15, 2007 | 05:52 PM
bud-weis's Avatar
bud-weis
Football Cwazy
The 'book' lists them as being different from the pinto bearings.
Old Jul 15, 2007 | 05:57 PM
Jim Green's Avatar
Jim Green
Thank You Martin........I knew I wasn't going crazy.
Old Jul 15, 2007 | 05:59 PM
Fiecos Dan's Avatar
Fiecos Dan
i know that,
But why, i know the meterial is different, but is that the only reason?
As these are heavy duty Pinto items (so lead/copper)
Old Jul 15, 2007 | 06:06 PM
bud-weis's Avatar
bud-weis
Football Cwazy
Originally Posted by Fiecos Dan
i know that,
honestly i don't know...if only Karl would pay his Ł200!!!
Old Jul 15, 2007 | 06:08 PM
Moonstone Steve.
how inconsiderate of him, just when i need some advice on another thread to
Steve.
Old Jul 15, 2007 | 06:53 PM
marco polo's Avatar
marco polo
the idea behind ford/cosworth using lead/copper bearings is that they wont damage the crank ie softer than the crank
marco
Old Jul 15, 2007 | 09:26 PM
Fiecos Dan's Avatar
Fiecos Dan
marco
Sorry, i dont know what you mean by that comment?
Old Jul 17, 2007 | 06:49 PM
Jim Green's Avatar
Jim Green
Hence cosworth cranks normally don't need a regrind, just a polish when your doing a rebuild.
After 40k.....my engine was stripped down and the crank was still perfect and no re-grind needed. They just re polished the journals and fitted std size bearings.
Old Jul 17, 2007 | 07:09 PM
Fiecos Dan's Avatar
Fiecos Dan
Thats the same for most engines which are looked after.
Anyway, Spoke to my supplier/machinest, and these are what he always has sold for cossie, and no come backs in 4 years.
He also said they are pinto shells, but uprated lead/copper, which is the same material as cossie's are std.
Old Jul 17, 2007 | 07:19 PM
Jim Green's Avatar
Jim Green
As long as your happy.
I'd just prefer to buy the real thing from Woodford though, but that's just me.
Old Jul 17, 2007 | 07:21 PM
Fiecos Dan's Avatar
Fiecos Dan
i see what your saying.
But not all ford parts are the best in quality, and
Not all woodfords stuff the real thing.
i got some stuff of them last week that was meant to be genuine ford, but it werent.
Old Jul 17, 2007 | 07:24 PM
Jim Green's Avatar
Jim Green
Yep....know what you mean, they sent me a paper sump gasket once instead of the real thing.
But when I got my new bearings they came in sealed platic containers and had the word Cosworth on them.....If you tell them you want the genuine Cosworth item, then you'll get it. (Once they know you know what your talking about)....LOL
Old Jul 17, 2007 | 07:25 PM
PGT's Avatar
PGT
I'd prefer to buy the real thing from cosworth - half the price that woodford charge for bearings
Old Jul 17, 2007 | 07:26 PM
Jim Green's Avatar
Jim Green
There You Go.....
mk22door
49
Mar 26, 2022 07:15 AM
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
Blown Hell
Aug 5, 2015 07:22 AM
