ST24 performance upgrades, whats best BHP per £?
Old Jul 13, 2007 | 08:40 PM
Rob_ECossie's Avatar
Rob_ECossie
Default ST24 performance upgrades, whats best BHP per £?
What are the best performance upgrades for the ST24, currently has a HKS induction kit fitted but otherwise standard.
I have been told that changing the exhaust and manifolds would give a big hike in power, is this true?
Any help appreciated!
Old Jul 14, 2007 | 04:06 PM
Jamie200's Avatar
Jamie200
Get a hold of ST200 upper and lower inlet manifolds is the next mod, along with the TB as well.
If you can't get a hold of them, spend some time removing yours and clean them up, they get very gummed up in a short time.
Changed the water pump to a metal impellored one yet?
Change the exhaust, yes but it won't give a huge hike in power but it will sounds great. when you do the exhaut it's worth removing the "Y"-pipe and removing the terrible restriction in there when Ford crushes two pipes into one. Takes time, a grinder and a welder but definately worth doing for the last few bhp,
Old Jul 14, 2007 | 11:40 PM
Rob_ECossie
Cheers mate, the water pump has just been done before it was bought with receipt to prove thank god.
I've found an ST200 breaking so I'll get straight on the case with that one.
Old Jul 15, 2007 | 10:05 PM
Jamie200's Avatar
Jamie200
Good man, get as much off it as you can and good luck!
Old Aug 4, 2007 | 07:54 AM
bluescortcossie's Avatar
bluescortcossie
the st220 (mk3) throttle body fits straight on and you dont have to bugger about with the cables like you do with the st200 unit , but if you know where there is a st200 in a breakers then it probably cheaper to go with that than buying new
Old Oct 1, 2007 | 04:11 PM
sandman666's Avatar
sandman666
Jamie...where abouts on the exhaust is the y pipe,i only ask as i`ve had a full stailess decatted system fitted and now im wondering if its been removed or not...cheers.
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Sp3no
Sep 27, 2015 07:23 PM
