anyone on here use zymol waxes etc?
what are they like?ive heard they are the dogs danglies but expensive.
and roughly how long do the pots last?
cheers neil.
cheers neil.
with the right prep, ie polish sealers or cleanses zymol is fantastic.
think they do a starter kit
http://www.vertar.com/zymol/zymol-starter-kits/
£99 the cheapest
£99 the cheapest
Originally Posted by NIL 7717
that aint too bad depending on what you get.will have to hunt for the info on how much you get.was wondering if its worth changing from meguiars.
poorboys is also excellent, i use a lot of there polishes and trim cleaners.
all depending on what you are using, a machine or hand to polish and wax.
if by hand then you will probably not see much improvement over the meguiars apart from perhaps a deeper longer lasting shine.
if you are going down the machine polishing route id highly reccomend the menzerna range of polishes and then zymol as a sealant/glaze.
i do all my stuff by hand.i hate machines. im not sure what to do yet.
if i did it would be the expensive stuff tbh.
anything with turtle wax on i would stay away from.
I used to use this before I moved to Poorboys which says a lot for poorboys
, I was using Carbon to start with and then I changed to Titanium, all applied properly with HD cleans etc, it is good but I think Poorboys is better and it is MUCH cheaper, I have seen very good results with their Concours glaze though
I think it depends on what finish you want also, as MATCOS said i also use poorboys as its better in some areas n also cheaper but i do like the finish of the zymol waxes over any of the poorboys such as natty blue.
you will end up like me and most others probably with a shelf FULL of polishes waxes, sealers and glazes lol.... its an expensive hobby keeping ya car clean
Originally Posted by jaiscossie
personally i dont think you can beat p21s as a last coat wax as long as your paintwork is perfect as this is just pure wax
Adam Graham
Sep 6, 2015 06:04 AM
Sid
52
May 9, 2006 06:35 PM
Benn 304R
Feb 15, 2006 08:16 PM
