Zetec conversion loom/wiring
Old Jul 12, 2007 | 08:20 PM
Jamie200's Avatar
Jamie200
Default Zetec conversion loom/wiring
I'm planning on putting a 2.0 silver top Zetec into a 1990 efi mk4 XR3i.
I know of all the mechanical mods needed, and although I've trawled for ages on managment and looms, I still need some ideas:
I have the ecu and loom and engine from original efi xr3i.
I have all running gear and loom/ecu from K plate 1.8 105ps (non-pats)
I also have full car- 96 1.8 Si.
I want to use Ford parts so what ecu/loom combo do I use?
1: XR3i Efi set-up? (with inlet manifold adaptor plate)
2: either 1.8 set-up from above Escort? (Will this run 2.0 ok?)
3: Mondeo set-up if I get whole car?
I understand the loom needs modded to use 2.0 ecu, but is this only on 1.8 loom?
Does anyone have exact wires or connectors that need modded to fit 3i?
Thanks to all who reply.
Old Aug 16, 2007 | 09:08 PM
rigwrecker's Avatar
rigwrecker
try posting in the tech part ul get answers there
Old Aug 16, 2007 | 09:19 PM
Jamie200's Avatar
Jamie200
Thanks, I did but didn't get a response.
Old Aug 17, 2007 | 11:13 PM
rigwrecker's Avatar
rigwrecker
just keep ur post at the top off the page and someone will answer ever if all u put is
anybody??? lol
then someone will answer
Old Aug 19, 2007 | 09:47 PM
Jamie200's Avatar
Jamie200
Cheers, may give it a try!
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
